Ever since I installed my new power supply which is this one:
http://www.newegg.com/Product/Prod [...] 6817103942
sometimes my computer doesnt turn on or the light around my turn ons creen doesnt light up, but the fans do and they seem to turn on loud as well (than usual). But when i turn it back off (the fans) and press it again it turns on. I am not sure if its a psu problem (too much under load) or if its my hard drive. I am running a 9800 gt 2x 46000+ anthlon, 4 gigs ram, one hard drive.
Sponsored Links
430 W power supply is too small for a 9800 gt 2x....
Reply to runmymouth
I have a regular 9800 gt.
Reply to Pershing121
Your gpu is taking 300W under load, cpu takes ~100W. I doubt this thing is actually even giving you 430W (most don't give cited power). You really need a 550W or more for a 9800
Reply to runmymouth
well it seems to work most of the time and forum members on here recommended it.
also, it doesnt turn on at the beginning unde rload I would imagine so why would it not always turn on (the cpu)?
It sounds like a load issue to me. Otherwise your motherboard,cpu, or gpu are bad.
Reply to runmymouth
I just thought of something else that has happened to me before. Bad ram might be the culpurate. Also the thermal paste may not be on properly on your cpu.
Reply to runmymouth
when you say load do you mean my psu doesnt know how to direct the amps on the 12v rails correctly or that my system has too many things for it to load up?
Too many things are drawing power for how much power is available. If you have an old power unit try plugging the video card in through that with the case open to see if it will boot.
Reply to runmymouth
You tried disconnecting non essentials yet to see if it makes any difference? Fans, DVDs, HDDs etc etc. Does it boot to windows when you do get it to start? Have you managed to do any kind of stress testing and if so is it stable?? PSU shouldnt be too hard to rule out if it is too weedy to power your system.
Reply to spunker
actually, it boots to windows and plays games and everything when it starts. and most of the time it does start, only sometimes it doesnt and only the fans do.
So it is abborted starts and not no boot. Does it ever crash and just randomly turn off in the middle of games?
Reply to runmymouth
OK, that rules out underpowered PSU then. Im getting too technical for myself here but i would only guess that it is either an intermitant fault with the PSU or with the motherboard power management. Just cant see why any other components would cause that kind of issue. I suppose my next move would be try another PSU so at least you could rule that out, if of course you can lay your hands on a spare one.
Reply to spunker
I was thinking my hard drive though cause it for some reasons makes a lot of noise sometimes after loading an app and wont stop making that loading/being really busy with data noise until i turn it off and back on.
Message edited by Pershing121 on 01-16-2009 at 11:14:58 PM
Maybe you do have an issue with your harddrive but i just cant see the connection with that and your startup problems. In my experience with faulty harddrives i have always managed a post screen and bois at least. When your system fails to power up does it make the crazy HDD sound at that point? Do you have an old PSU or HDD you can try?
Reply to spunker
no it doesnt make that weird noise (like its loading something), it only does it after I play a game for a while or installed some large program, or got some windows error.
I think maybe your computer has poltergeist, you certainly do have weird problems. My guess is that the HDD problem is quite possibly software as it sounds like it is just being accessed like crazy. All the faulty HDDs i remember either dont work at all or just make strange skippy noises. As for the power up issues ive still got my money on PSU/mobo. Hopefully someone a little wiser than me may be able to help you a little better than me. By this point i would have my pc in bits ruling them out 1 by 1.
Reply to spunker
A possible explanation. Especially if the current(s) are close to max, or (Not Your case) cheak a** PSU.
It could be a problem with the inrush current. When you first power on the current Can be very high for a short time ie milliseconds and may be interering with the "I'm OK" signal. When the power is turned off and back on some of the capacitors are still charged and the inrush current is lower. Note, as MBs age the inrush current increases primaily due to capacitor aging. Only whay to rule out is to try a Higher wattage PSU
In rush current is one of the reason slow blow fuses are used in may electronic systems. This is the reason that Lights may flicker when you turn on a vacuum cleaner
Reply to RetiredChief
it always turns on the second time I try it after it doesnt work and I turn it off and back on.
Then what you do is go through the scientific process. First and foremost, run a ram check. Any weird/interesting things can be symptoms of erratic ram. If that checks out after the 7th pass or so, then you go through the line.
First, you remove all PCI/PCI-e cards possible. I cant tell you how many people have purchased new computers because of a shorting modem stopping their pc in it's tracks.
After this, use a Powersupply tester to quickly check that your powersupply is both supplying the correct voltages and ampres, and it does not overvoltage. You can get one from newegg.com, just search for power supply tester.
If the power supply is running well, and you have only the essentials plugged in, then the power supply is not the culprit.
Now, remove all but one stick of ram. Place it in the slot closest to the CPU, and test. If it's still not working, move it to the next slot. If it's STILL not working, you've ruled out both ram, and faulty ramslots.
This leaves you with either a malfunctioning motherboard and or CPU. Now you can decide if it's worth it to take it to a local PC shop to have them test the Motherboard/CPU on their equiptment, or to replace the combo outright.
Reply to Curnel_D
If this is a new psu, and things were working before, then you must suspect the psu. It could be faulty, or underpowered.
It should be ok, but failures are not unknown.
First, though,run memtest86+ for a pass or two to check that the ram is ok.
Next, run prime95 for 30 minutes or so, with rounding checking to test the ram in a different way, and also the cpu. Look to see if there are any errors, and look for abnormally high temperatures. Monitor the temps with speedfan or similar.
Are you overclocking anything? A failed start can be a symptom that the bios needs to reset itself. unplugging the psu can sometimes do that. Back off any overclocks. Check the gpu clocks, and reset to standard.
What mobo/cpu/ram etc are you using?
Message edited by geofelt on 01-17-2009 at 05:43:45 PM
Reply to geofelt
are there any power supply testers I can download online for free?
oh I found out its a piece of hardware that plugs into your psu not software?
I am overclocking the cpu with nvidia control panel. Maybe that could be it as it even starts overclocked. The thing is when I increase the percentage on the fans using speedfan it doesnt change the speed, and I have no idea how to use nvidia control panel in changing my fan's speeds so its always too hot when playing games (like 62-65).
Good comments and recommendations from curnel_D and geofelt.
As to question on hard drive - Create a memtest boot disk, disconnect HDD (Both power and data). After extended “Off Time” See if it boots to CD on first try. Then as others stated – Check memory.
Ref: PSU testers. These are a good go-no go tester for a new PSU, or one that you think died. They only check votages, not currents as they simulate a very light load.. These testers are very cheap when compared to a “Real” PS tester ( ie 20 bucks vs several hundred dollars. The best, and possibly the only, check would be to replace the PSU with a known PSU .
I’m still leading toward a PSU problem with inrush current and/or the Good_OK signal (Pin 8 on 20/24 Pin MB Connector. Rational is that it doesn’t power on on first try, but does on 2nd try and this seams consitant..
Quote from Wikipedia
The Power-Good signal is a +5 volt (V) signal generated in the power supply when it has passed its internal self-tests and the outputs have stabilized. This normally takes between 0.1 and 0.5 seconds after you turn on the power supply switch. The signal is then sent to the motherboard, where it is received by the processor timer chip that controls the reset line to the processor
End Quote
Message edited by RetiredChief on 01-17-2009 at 09:48:13 PM
Make/model of your mother board?
Reply to Economister
the weird thing is, when I first put in any new psu it doesnt boot from cd but tries reinstalling windows. Before it goes to the reinstall windows screen off the cd it says:
Yukon PXE V5.16.1.3
client mac appr
00 19 21 F11921
ANd some other crap than on the bottom it says:
DIsk boot failure
insert system disk and press enter
I dont remember actually but I might not have had the disc in by that point or I might have. But after I turn it off and on again I can go back to windows with all my previous programs and everything works without having to reinstall windows.
Yukon PXE V5.16.1.3
client mac appr
00 19 21 F11921
DIsk boot failure
The above info makes me think your computer is trying to boot from the network, rather than from your C: drive. Info on PXE: http://en.wikipedia.org/wiki/Prebo [...] nvironment
If you don't want to boot from the network, you can probably disable that feature from within the BIOS.
Reply to the daveman
well it works now and boots from cd (as it states despite no boot disc being in drive) it does this every time I install a new psu though.
ok guys this is really bad, now it does it like 3-4 times in a row before it eventually powers the system on. Is my brand new psu dying or something?
Is it possible that the battery in the mobo is bad/weak, and can't hold the changed bios settings, and is reverting to the default each time power is removed?
Reply to geofelt
it does it even when I put my overclock at startup back to default settings in nvidia control panel, so what changed bios settings would it deal with outside a new psu?
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Weird problem
There are 1025 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
