Graphics Card: ASUS EAH4850 TOP/HTDI/512M Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
HardDrive: Western Digital VelociRaptor WD1500HLFS 150GB 10000 RPM SATA 3.0Gb/s Hard Drive (bare drive) - OEM
Memory: CORSAIR DOMINATOR 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory Model TWIN2X4096-8500C5DF - Retail
I am torn between these two Processors,: Intel Core 2 Duo E8500 Wolfdale 3.16GHz LGA 775 65W Dual-Core Processor Model BX80570E8500 - Retail
and Intel Core 2 Quad Q6600 Kentsfield 2.4GHz LGA 775 Quad-Core Processor Model HH80562PH0568M - OEM
Mobo: ASUS P5Q Pro LGA 775 Intel P45 ATX Intel Motherboard - Retail
Power Supply: Antec EA650 650W ATX12V Ver.2.2 / EPS12V version 2.91 SLI Certified CrossFire Ready 80 PLUS Certified Active PFC Power Supply - Retail
Primary questions are as follows: In regards to the processor is it better to get the quadcore for "future proofing" I have read that the overclocking potential on the quad drive is incredible, even with stock fans.
Aside from that, is the Mobo a decent choice for the setup I have listed here, and are there any extras I should be concerned with aside from what I have listed here? I am going for a good gaming build that doesn't kill my wallet though I am splurging on a few things (hard drive, monitor) any comments or suggestions would be greatly appreciated, thanks.
