Tom's Hardware > Forum > Homebuilt Systems > New System Build > NO Post on Ausu P5E3 Deluxe - Help!
Forum Homebuilt Systems : New System Build - NO Post on Ausu P5E3 Deluxe - Help!
Here is a list of the stuff that I got:
1) OCZ Gold Edition 2GB (2 x 1GB) 240-Pin DDR3 SDRAM DDR3 1333 : http://www.newegg.com/Product/Prod [...] 820227246)
2) Intel Core 2 Quad Q6600 Kentsfield 2.4GHz : http://www.newegg.com/Product/Prod [...] 819115017)
3) Western Digital Caviar SE16 WD5000AAKS 500GB 7200 RPM 16MB Cache SATA 3.0Gb/s : http://www.newegg.com/Product/Prod [...] 822136073)
4) Thermaltake Armor+MX VH8000BWS : http://www.newegg.com/Product/Prod [...] 811133062)
5) ASUS P5E3 Deluxe/WiFi-AP LGA 775 Intel X38 : http://www.newegg.com/Product/Prod [...] 1681313121
6) Thermaltake W0116RU 750W Complies with ATX 12V 2.2 & EPS 12V : http://www.newegg.com/Product/Prod [...] 6817153038
7) MSI R4850-512M Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 : http://www.newegg.com/Product/Prod [...] 6814127370
I set it all up with only 2 ram modules (btw I bought 4 sticks), and powered it on, the lights all come up on the board, but no post screen, no beeps. Tried without the vga, and only ram. Tried without RAM and only VGA, tried all possible combinations and no beeps. i connected the mobo to speaker (System Warning Speaker) and no beeps. So can someone help me out?
Thanks alot!
Sponsored Links
Did you remember to plug in the 4/8-pin CPU power cable? It's the 8-pin connector with a cover over 4 pins in the bottom left of this picture right where the two heatsinks come together:
http://www.newegg.com/Product/Show [...] -%20Retail
Reply to shortstuff_mt
Did you remember to connect the 8 pin CPU power connector that is located near the back right corner of the mobo?
Beat me to it shortstuff_mt, was trying to eat and type at same time.
http://www.bit-tech.net/hardware/2 [...] ifi_ap_n/2
Message edited by rgsaunders on 10-23-2008 at 01:13:41 AM
------------------------------ Never under estimate peoples capacity for stupidity, and you won't be disappointed.
Reply to rgsaunders
I have an ASUS P5B DELUXE MOBO. One day it just stopped. The problem was the battery was not making contact. A firm push on the battery provided relief.
Reply to ddc22
Yes it works now... stupid me didn't see the 8pin cpu power connector... thanks for the help
Reply to scottvirus
There are 1144 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
