Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Loose Wire on Seasonic SS-600HM 24 Pin Connector. Help!
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Loose Wire on Seasonic SS-600HM 24 Pin Connector. Help!
Ok, while swapping out my MB, I noticed I have a loose wire on my 24 pin connector. It is a small orange wire that was bent so the area of pin 1, 2 and 13 side. Anyone have a Seasonic power supply that can look to see which pin it actually goes to?
For reference pin 3 has a small black wire going into it with the other normal wire. So I assume the orange is the same.
I was able to get pin 2 out with my molex tool. I just need a quick look from someone to verify which pin this wire goes to.
Thanks in advance!
If you have anothe version of the Seasonic PSU, any info would be helpful!
Sponsored Links
Pins 1,2,12 and 13 are the 3.3 volt ( orange wire ) lines on a standard ATX main connector
------------------------------ q9650 @ 4.050 | Asus Rampage Formula | 2x2 Corsair Dominators | WD Black 640 x2
EVGA GTX260 Core216 @ 686/1479/1103 | Antec TPN 750
Reply to Delluser1
There are 623 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
