Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help me build a pc(now please critique)
Forum Homebuilt Systems : New System Build - Help me build a pc(now please critique)
original post-
Spoiler :
Ok firstly. im going to make a gaming pc and i wont overclock the processor ( never dare to do so )
My budget just abt 550USD-625USD
Im stuck between AMD Phenom 9950 Black Edition and Intel E8500.
confused which is better..
I think i should take E8500. gaming purpose.
If possible, list me good/recommended components for the processor... All i want for my pc just...
Processor
mobo
ram- any ddr2, 2gb, good and not too exp
graphic card - any but good for gaming, 256mb/256bit if possible.
power supply
Hard Disk - Sata 160gb ( sata better right? )
Casing <-- normal and cheap enough lol.
Im used to play online game, multi client... =/ help me to build a new pc..
added--
processor-c2d E8500
power supply- i duno..
mobo- Gigabyte EP43-DS3L
hd- wdigital 7200rpm, 16mb - 320gb
RAM-Mushkin ddr2 value series, 2gb, pc6400
graphic- HIS 4850 HDMI 512MB DDR3
total price - 558 USD.. not bad >_>
followed some opinions, i got those components. any1 can critique/comment if theres anything wrong?
im afraid some components arent compatible.. some1 can check them for me? i really appreciate it..
(total price exclude the casing price, can consider at shop later >_< )
ps: help me in picking PSU...
Message edited by rufaz on 10-23-2008 at 11:13:26 AM
Sponsored Links
You'll have to squeeze hard to get everything you need into that price range.
Probably a E7200 and P43 MB,
Then a 9600GT (512MB)
Antec 300 case with a combo deal PSU
Jump over to this thread and have a read....
http://www.tomshardware.com/forum/ [...] rts-choose
You want more graphics power and less CPU to stay balanced. A E8500 would not do you much good without the video card to play the games.
Reply to Proximon
Case - Antec 300 $60 free shipping. Combo deal is $20 off the power supply.
http://www.newegg.com/Product/Prod [...] 6811129042
Power supply - Antec Neopower 550w $50 - $20 in combo deal with case.
http://www.newegg.com/Product/Prod [...] 6817103941
*EDIT* replaced below.
RAM - 2x1 GB DDR2 800 1.8v OCZ gold - $17 after rebate
http://www.newegg.com/Product/Prod [...] 6820227124
HD - Seagate 250GB SATA - $50
http://www.newegg.com/Product/Prod [...] 6822148261
Burner- LG Sata - $25
http://www.newegg.com/Product/Prod [...] 6827136153
Operating system - Vista Home Premium 64bit $100
http://www.newegg.com/Product/Prod [...] 6832116488
$652 before shipping, $70 in rebates ....$17 in shipping to me.
Message edited by dirtmountain on 10-23-2008 at 07:33:55 AM
Reply to dirtmountain
This build is more than you wanted, but still falls into your budget if you take the rebates into account:
Intel Core 2 Duo E8500 Wolfdale 3.16GHz 6MB L2 Cache LGA 775 65W Dual-Core Processor - Retail
http://www.newegg.com/Product/Prod [...] 6819115036 $189.99
GIGABYTE GA-EP43-DS3L LGA 775 Intel P43 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/Prod [...] -ep43-ds3l $86.99
I know you said you only needed 2GB, but RAM is so cheap right now you might as well get 4GB.
mushkin 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Prod [...] 6820146731 $69.99 -$20.00 MIR
A smaller HD would not save you much $ and would be slower.
Western Digital Caviar SE16 WD3200AAKS 320GB 7200 RPM 16MB Cache SATA 3.0Gb/s Hard Drive - OEM
http://www.newegg.com/Product/Prod [...] wd3200aaks $59.99
This GPU is also more than you said you need, but is a great deal on an awesome card.
HIS Hightech H485F512P Radeon HD 4850 512MB 256-bit GDDR3 PCI Express 2.0 x16 HDCP Ready CrossFire Supported Video Card - Retail
http://www.newegg.com/Product/Prod [...] 6814161235 $164.99 -$30.00 MIR
Antec Three Hundred Black ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Prod [...] 6811129042 $54.95
Antec NeoPower 550 550W ATX12V SLI Certified CrossFire Ready Active PFC Power Supply - Retail $29.99 (Combo with case)
This comes to a total of $656.89 -$50.00 MIR = $606.89
Throw in a DVD burner and 64-bit Vista and you would be set.
SAMSUNG Black 22X DVD+R 22X DVD-R 16X DVD-ROM 2MB Cache SATA 22X DVD±R DVD Burner with LightScribe - OEM
http://www.newegg.com/Product/Prod [...] _-Homepage $26.99
Microsoft Windows Vista Home Premium SP1 64-bit English for System Builders 1pk DSP OEI DVD - OEM
http://www.newegg.com/Product/Prod [...] 6832116488 $99.99
Reply to shortstuff_mt
- 0 +
lol. OS not important, wont cost me a cent.. i will be using XP. I dont really like vista, nt much diff with xp, just more complex and beauti'fool' to me =x im used for XP. =)
throw away dvd/cd driver. dont need them too. i have the old one.
Message edited by rufaz on 10-23-2008 at 07:18:36 AM
Reply to rufaz
If you have a tight budget, take a look at the e7300. It's only 130USD and runs at 2.66 ghz.
http://www.newegg.com/Product/Prod [...] 6819115132
With the money you save on the processor, you can get an Asus P5Q Pro P45 motherboard with another $20 rebate.
http://www.newegg.com/Product/Prod [...] 6813131299
------------------------------ http://valid.x86-secret.com/cache/banner/430630.png
Asus P5Q Deluxe,
Q6600 @ 3.0 ghz (333x9),
EVGA 8800GTS 320MB stock,
Reply to aeiouandxyz
Well I stand corrected, those builds are less than I thought they would be :)
Reply to Proximon
whoa, an extra $125 to play with!
This graphic card then. HD4850 OC $140 after rebate
http://www.newegg.com/Product/Prod [...] 6814121272
E8500 - $190 includes a combo deal on mobo.
Motherboard - Gigabyte P45 UD3P crossfire capable $92 after rebate and combo deal with the E8500
http://www.newegg.com/Product/Prod [...] 6813128358
- 0 +
processor-c2d E8500
Message edited by rufaz on 10-23-2008 at 11:13:08 AM
Reply to rufaz
Yes you switched to a an inferior power supply that could hurt your components on simply cause your system to be unstable.
(If you had read the first link I posted you would have known that.)
Also there seems to be no case?
Reply to Proximon
- 0 +
omg >< ok then
case - think abt that @ shop =p
abt power supply.. can you recommend me which 1 is compatible, =/ i really dont know..i dont even understand about the way to get a compatible power supply =/
Message edited by rufaz on 10-23-2008 at 10:15:22 AM
Reply to rufaz
- 0 +
These are my specs,
processor-c2d E8500
hd- wdigital 7200rpm, 16mb - 320gb ( SATA, 1 pcs)
RAM-Mushkin ddr2 value series, 2gb, pc6400 ( 2GB, 1 pcs, might go for 2 later... )
graphic- HIS 4850 HDMI 512MB DDR3 ( 1 pcs )
Samsung CD/DVD RW SHS-S182 - 1pcs
lack anything?
im not really sure, im still new in these things.. I calculated and i got 324W, i count again use another calculator, i got 288W...
like i said, im just a noob, some1 can recalculate and confirm it for me? =) to make sure it is right=/
Message edited by rufaz on 10-23-2008 at 11:23:13 AM
Reply to rufaz
You do not need a big power supply, as long as it's a quality one.
I would recommend:
Antec EA500, Neo Power 550W, or EA430
Corsair 450VX
OCZ StealthXStream 500W
And others, but those should have good prices.
Reply to Proximon
- 0 +
hw about Thermaltake Litepower 400W... or Thermaltake TR2 RX 450...
>_< those brand that you recommend arent sold around my place =/
Message edited by rufaz on 10-23-2008 at 07:21:08 PM
Reply to rufaz
There are 1066 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
