Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Help with memory fix for new build
Forum Homebuilt Systems : General Homebuilt - Help with memory fix for new build
Help with MEMORY…
I have the following--MOBO Gigabyte EP45-DS3R--PROCESSOR Intel E8400 Core2Duo--MEMORY Mushkin XP2-6400 Ascent 4GB--Vista 64
My computer runs nearly flawlessly with 1 2GB RAM installed…as soon as I load the second RAM of 2GB the computer has numerous problems such as the BSD, numerous restarts, sudden failures to boot up, etc……I have tried a few times to verify and same every time…..2 GB good 4 GB bad……
I have 2 questions.
1 If I add 4 more GB of RAM will that fix problem because there is a 4 gb vs Vista issue?
2 Can anyone point me towards the previous discussions in the forums….I am having trouble finding data…..Thank you in advance.
------------------------------ Intel Core 2 Duo E8400 Wolfdale 3.0 GHz LGA 775, Gigabyte EP45-DS3R MOBO, Nvidea 9800GTX XXX PCIe2.0, Vista64 Home Premium, Mushkin XP Ascent 2 GB (4GB when working) DDR2 800, PC Power and Cooling 610Watt EPS12V, XigmaTek HDT-S963 heatsink, Seagate 640GB
Sponsored Links
While I'm certainly not a memory expert here, my first concern would be that the motherboard specs list 1.8v memory supported whereas the Mushkin XP2-6400 memory is listed as 1.9v.
Also, when you're adding the second stick of RAM, are you installing it into the same color memory slot as the first?
Have you attempted to run the system on just the "bad" memory installed into the first slot?
How about Memtest86+? Have you run that against each memory module, individually?
Just a few ideas off the top of my head.
-Wolf sends
------------------------------ System Specs:
Gigabyte EP43-UD3L Intel Core2Quad Q8400 8 Gig RAM
NVidia Geforce 8800GTS-640/Creative X-FI Extreme Music/Dual-Boot XP-64&Server2008
Reply to Wolfshadw
There are 1037 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
