Tom's Hardware > Forum > Homebuilt Systems > New System Build > Help with new build memory issue
Forum Homebuilt Systems : New System Build - Help with new build memory issue
Help with MEMORY…
I have the following--MOBO Gigabyte EP45-DS3R--PROCESSOR Intel E8400 Core2Duo--MEMORY Mushkin XP2-6400 Ascent 4GB--Vista 64
My computer runs nearly flawlessly with 1 2GB RAM installed…as soon as I load the second RAM of 2GB the computer has numerous problems such as the BSD, numerous restarts, sudden failures to boot up, etc……I have tried a few times to verify and same every time…..2 GB good 4 GB bad…
I have 2 questions. 1 If I add 4 more GB of RAM will that fix problem? 2 Can anyone point me towards the previous discussions in the forums….I am having trouble finding data…..Thank you in advance.
------------------------------ Intel Core 2 Duo E8400 Wolfdale 3.0 GHz LGA 775, Gigabyte EP45-DS3R MOBO, Nvidea 9800GTX XXX PCIe2.0, Vista64 Home Premium, Mushkin XP Ascent 2 GB (4GB when working) DDR2 800, PC Power and Cooling 610Watt EPS12V, XigmaTek HDT-S963 heatsink, Seagate 640GB
Sponsored Links
Sorry about the dual post
Reply to Gr8Timz
Is this your RAM?
http://www.newegg.com/Product/Prod [...] 6820146793
If it is, you need to make sure the voltage and timings are set correctly (4-4-4-12 @ 2.1v). If the timings and voltage are correct, you need to download Memtest86+ and run it for at least 8 hours to test for defective RAM.
Reply to shortstuff_mt
That is my memory.... I will try to set those specs in the bios but I am unfamiliar with BIOS operations....trying to work it now with 2 gbs in
Reply to Gr8Timz
Another example of why getting RAM that runs on the JEDEC standard is the best way to go.
I like Mushkin, but always get a set that runs on 1.8V. It is either 5-5-5-12 or 5-4-4-12.
You may also have gotten a bad RAM stick. Does it work with either stick but not both? Does it matter which slot you use for one working stick?
------------------------------ There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
both sticks good in slot 1 will try other slots
now i need to look up jedec and see what i did not know when i bought what i have
Reply to Gr8Timz
Gr8Timz I know this will sound stupid,your ram slot are 2 yellow and 2 red when you insert both ram chips which ones are you using?
------------------------------ ▐ ASUS RAMPAGE EXTREME II ▐ I7 920 ▐ 3 GIG CORSAIR 1600 ▐ BFG 280 GTX ▐ ANTEC 850 PSU ▐ ANTEC 900 CASE ▐ ACER 22" 2216WB LCD ▐ SAITEK ECLIPSE II ▐ LOGITECH G5 ▐
Reply to major53
There are 1176 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
