I was wondering if there is any virtual machine software out there that supports directx 9c SM3 or better using Windows XP as a guest os? I can't seem to find if VirtualBox does and it looks like VMware workstation only does 9c SM2.
A while back when, I started researching for my new PC, I wondered the same thing, but I never found any VM that could do Direct3D. What exactly are you trying to do?
I wanted to test out a app/game that I'm writing but wanted to isolate it from my host.
put a 2nd install of xp on a different drive or partition, and dual boot it. that will keep your good install clean, and let you do as you wish with the 2nd.
As michiganteddybear suggested, dual boot might be your only solution, but you will have to reboot between compilation and tests. Is the game you are programming unstable to the point where it could dammage the OS you are executing it on? Maybe you don't need a "sandbox" to test ...
I was hoping to not have to reboot between compilations.
I'm not completely sure about it's stability yet, just started a while back. Plus if it were to crash I wouldn't want to reboot every time if my system hangs. I was looking at developing in Linux and running it in XP. Right now I'm running XP.
