Im looking for a motherboard that is a good overclocker and stable. I have done a ton of research but i just cant decide. Its the only part im not sure on so maybe you guys can help. I have experiece with a AM2 dfi board if that helps. My system should be as follows
e8500
Mushkin 2x2g 6400 5-5-5-15
Sapphire 4850
WD 640g HD
CM 690
Silverstone 700W PSU
XIGMATEK HDT-S1283 120mm w/ bracket.
School Provided vista buisness 64bit
So any mobo suggestions
e8500
Sapphire 4850
WD 640g HD
CM 690
