Tom's Hardware > Forum > Graphic & Displays > ATI > HW Monitor, GPU-Z and CCC can't all be wrong, can they?
Forum Graphic & Displays : ATI - HW Monitor, GPU-Z and CCC can't all be wrong, can they?
I've been reading a few reviews/benchmarks on the 4850 circa June 2008, as well as various posts on these boards, and I've noticed that these cards apparently run really hot. I've seen numbers like 70C-80C idle and +100C gaming.
I have the Asus HD4850 and have OC'd it to 690/1148 via CCC's Autotune, and my temps are 40-43C idle, and ~60C gaming (COD4). Fan is at 65%.
I have turned looked at HW Monitor, GPU-Z and CCC (8.10) simultaneously, and they all show the same temps.
Sure, I have a big, spacious case (Antec P182), but can my card be THAT much cooler? I have no aftermarket GPU cooler either.
Do my temps seem right to you guys? And maybe some of you with the same card could give your own temps as reference.
PS. my temps before OC'ing were the same, only difference was that my fan was at 50%.
PSS. P5Q Pro; E8400 (no OC); 2x 2GB OCZ Plat DDR2 1000; 74GB Raptor; 1680x1050 res.
Message edited by kingtz on 11-22-2008 at 02:05:08 AM
Sponsored Links
I'd bet it's your case. I have the same card, but a crappy HP case, and get ~58c idle and it overheats at ~100c under load.
If I take the side cover off it'll idle at ~41c and only get to ~70c under load...
Reply to Taiketo
^wow that is insane! does that hp case actually have any case fans?
Reply to V3NOM
One on the back, but it's a really crowded case..
Here's a pic, sorry for the quality..
Message quoted 1 times
Message edited by Taiketo on 11-25-2008 at 11:41:33 AM
Reply to Taiketo
most reviews probably use styock fan speeds.
------------------------------ I'm a git, deal with it.
Antec 1200,PC Power & Cooling 750,Gigabyte DS4-x48,Intel Q9550@3.4 W/Xigmatek S1283,8GB OCZ DDR2 800,ATI 4870X2,X-FI>CA 640C amp>Tannoy R300/Senn 595's
Reply to strangestranger
Holy cow, now that's crowded!
I used to have a case about as big as yours, and I too, had to keep the side open with a regular fan constantly blowing into it. My 6800GT still burnt out 3 times though, but back then I didn't know about monitoring temps, unfortunately.
Reply to kingtz
That could be, since they predate 8.10, but surely there were other means to change them.
Reply to kingtz
Yes, but unless stated otherwise a review site will just use stock. They are not looking for any effects of long term use, they may only be getting a loan of the card so unless the card is unstable they won't care.
the old stock hsf of the 4850 resembles a frying pan. thankfully most of the distros are phasing them out and replacing them with custom coolers, some of them even has zalmans on it.
Reply to wh3resmycar
There are 1284 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
