Tom's Hardware > Forum > Motherboards & Memory > General Motherboard > PCI Slot Problem - Ruined three cards
Forum Motherboards & Memory : General Motherboard - PCI Slot Problem - Ruined three cards
I have a PC that after a few years of serivce and seeming to run fine.. the Capture card in a PCI slot gave out.. figured it had failed.. replaced.. tested ok.. ran for a few days.. and that one failed.. installed a third.. it also failed after a short time.. 4 5 days.. wondering how to ensure voltages are correct or any other ideas?
Sponsored Links
Have you tried the cards in a different computer?
------------------------------ *How To Ask For New Build Advice*
HAF 922 | HX750
Rampage2Gene | i7 920 D0 | 6GB Gold 1600 | Hyper 212+
Caviar Black 640GB | HD3870
Reply to theAnimal
- 0 +
after they stopped working? No.. since putting a new one into the machine made the unit function I stopped there.. but after the 3rd failure.. I am suspicous and going to try that.. just to make sure..
Reply to Bo1o1
There are 1253 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
