Tom's Hardware > Forum > Homebuilt Systems > New System Build > Build Revisions (need help cutting down costs)
Forum Homebuilt Systems : New System Build - Build Revisions (need help cutting down costs)
Alright, I'm going for the whole package here with this build. Please look through my items and help me shave some dollars if possible. For instance, I'm going with the Antec 900 case but is there an equivalent case for cheaper out there that you know of? Also, please share if you have any overall suggestions concerning the build, compatibility issues, etc.. I'm hoping this rig can stay with me for the next 4-5 years and able to play most demanding of games throughout that time. I'll most probably add in another 4850 down the line for CF.
Intel Core 2 Quad Q6600 Kentsfield 2.4GHz 2 x 4MB ($190)
http://www.newegg.com/Product/Prod [...] 6819115017
ASUS P5Q Pro LGA 775 Intel P45 ATX Intel ($105)
http://www.newegg.com/Product/Prod [...] 6813131299
Corsair 4GB (2 x 2GB) DDR2 800 (PC2 6400) ($40)
http://www.newegg.com/Product/Prod [...] 6820145184
Western Digital Caviar SE16 WD6400AAKS 640gb ($75)
http://www.newegg.com/Product/Prod [...] 6822136218
Corsair 750TX PSU ($82 w/ promo code esave15)
http://www.newegg.com/Product/Prod [...] ir%20750tx
SAPPHIRE 100245L Radeon HD 4850 512MB 256-bit GDDR3 ($140)
http://www.newegg.com/Product/Prod [...] 6814102770
Antec 900 Case ($80)
http://www.directron.com/ninehundred.html
Xigmatek S-1283 CPU Cooler ($36)
http://www.newegg.com/Product/Prod [...] 835233003&
Xigmatek Retention Bracket ($7)
http://www.newegg.com/Product/Prod [...] 6835233019
Samsung 22x DVD ROM/Burner lightscribe drive ($27)
http://www.newegg.com/Product/Prod [...] _-Homepage
Windows Vista x64 ($100)
http://www.newegg.com/Product/Prod [...] 6832116488
Acer 22" LCD ($180)
http://www.tigerdirect.com/applica [...] =A179-2240
Total: ~$1080 (including MIB)
Thanks!
Sponsored Links
That is a very solid build.
Each component you picked is quite solid. That will be a very nice build.
On the down side, there is really no fluff I would cut to save $$$.
Reply to Nytmare
That's a great build! You've really done your homework and shopped around for good prices.
I wouldn't change a thing except maybe pick up the OEM version of the CPU to save $10 since you've picked an aftermarket CPU cooler.
Reply to shortstuff_mt
This cooler rated higher at www.frostytech.com includes bracket and fan control for $25 after rebate.
http://www.newegg.com/Product/Prod [...] 6835207004
The Antec 300 case, $55 with free shipping
http://www.newegg.com/Product/Prod [...] 6811129042
combo deal with the Antec EA Earthwatts 650w power supply drops it to $55 with free shipping
and would be fine for crossfired 4850s.
Jonnyguru review of that power supply
http://www.jonnyguru.com/modules.p [...] y&reid=110
just trying to shave a little money off without impacting performance.
Reply to dirtmountain
- 0 +
well as others have said its a pretty nice build u have but u might wanna checkout the lcd on tigerdirect again cause it says unavailabe now...anyways if u still want to shave off some dollars then get this
http://www.newegg.com/Product/Prod [...] 6811119142
the case is equivalent or even better IMHO then the 900 which sounds like a jet engine with the above fan spinning full throttle...the 690 has around 9-10 fan accomodations and is very well built....i have one, plus the cable management is superior than the antec 900..search google for comparison; cm 690 vs antec 900......the deal also includes a cooler master real power pro 550watt PSU which is a better then their older extreme series power supplies...overall its a solid combo deal and easily enough for your current built...may be u can save some money on the case and PSU and get yourself an x48 mobo to get full 16x - 16x crossfire for the future but in that case 550watts wont be enough :P ....other then that u have a very nice built
Reply to mbbs20
- 0 +
hmm +1 for dirtmountain's recommendations
Reply to mbbs20
There are 699 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
