Hi, thanks in advance and apologies in advance as well, for this noob question I'm about to ask.
I'm buying a new PC since my last one died (burnt mobo). I'm planning on using this computer for everything: gaming (moderate), editing and ripping (moderate), office (highly), other stuff. Not really interested in the components themselves but I like very good performance, and high extension capabilities for the future. So far, my budget allows me the following:
And here's the issue: probably you noticed I'm missing the RAM modules. The thing is, I know I have to match frequencies. Yet, my conclusion so far is that: it's not possible with the chosen processor, right? The E8500 Intel's processor work with a real clock of 333Mhz, right? Now, I know the motherboard supports this processor since from ASUS' webpage:
You don't have to match the CPU and memory frequencies, but DDR3 1333 would match it. Just get memory that's on the QVL and be done with it. I haven't seen a 16 GB kit (4 x 4 GB) of DDR3.
Agree with ghislaing - you don't need to match frequncies, but, much more than 3Gb RAM won't really benefit unless you're using a 64 bit operating system.
Done then, I'll go then with 2Gb (2 x 1Gb) DDR3-1333, GSkill NQ Series... Then I'll upgrade those with another 2Gb, not for XP/Vista but for Ubuntu 64bits...
However, I'm still wondering... Is it better to have 1 x 2Gb or 2 x 1Gb?... Again considering that maybe I'll upgrade those later, let's say, by the end of this year... If I understand correctly, for Dual Channel to work you need two separate modules on the dual-channeled slots -the yellow ones on this mobo-, but I'm not aware of any "Quad Channel" stuff if you occupy the four slots at the same time... Any ideas?
Thank you guys, for your quick answer and your time. Again, I'm looking for your enlightenment here...
oh hang on. I'm not sure how Linux deals deals with RAM or if has the same limitations as MS operating systems....somebody else may be able to help.
That I'm aware of, there are no quad channel systems.
Given the choice always use 2 sticks of RAM (instead of a single stick of the same total value). This is the only way to enable dual channel mode and get its performance advantage. Make sure teh sticks are purchased together in a pack as this is the easiest way to guarantee that they are matched pairs.
There are DDR3 triple channels available, but make sure your mobo can support it (I don't think the P5Q3 does, but feel free to confirm!)
You don't need DDR3 at all. Get a mobo that takes DDR2 and get 2 x 2GB DDR2 800 that runs at 1.8-1.9V. (You are right 333 is 1:1 with DDR2 667 not DDR3 1333.)
That will allow the E8500 to oc to 3.8G. If you need to go higher than that get DDR2 1066, but only if you need an OC above 3.8G.
I would also swap the E8500 with a Q6600. The price differential is negligible and the extra two cores will come in handy. I just did a virus scan with AVG and set the slider to "Fast Scan". I watched the performance tab in task manager and AVG was hammering all four cores on a Q6600 OCed to 3.2G, and this is in XP. The two extra cores do get used and the Q6600 OCs to 3G at the drop of a hat, assuming a P3x/4x chipset.
When applying thermal paste with the Xigmatek cooler, apply a thin layer across the CPU IHS (top) or across the whole base of the heatsink. The paste won't spread properly through contact because of the gaps between the heatpipes and the base.
Message edited by Zorg on 02-25-2009 at 08:48:24 PM
You should go with 2 x 2 GB or 4 x 2 GB. They run in dual channel mode on your motherboard. Triple channel mode requires 3 or 6 modules on an X58 chipset motherboard and an i7 CPU.
Zorg, I can't promise I'll change mobo, memory and processor at this time, but I can promise I'll think about that option at least in a near future. The main idea is to have a PC that can (and will) be changed over time -3yr life span-... I'll probably won't stick to the C2D E8500, I can use it on my other PC, and buy a QuadCore when I'm ready for it... Yet again, with the i7 out there, I don't know if that would be the best idea... And what's worse, If I have to buy a QuadCore I'll try going with something higher than a Q6600, something 45nm and with a higher clock, like Q9550 but is WAY out of my budget right now...
[Maybe OFF-TOPIC] The problem with the Core2Duo vs QuadCore is the main use of the PC... For that matter, being a Systems' Engineering Student, to be honest, I use the computer for everything... From office apps, to programming, 3D rendering, video & audio edition, math app, home server configs and, of course, when bored gaming... So, as far as I know the best option would be to go with a QuadCore and just simply OC'it, but I'm not quite confident with OC yet. However, the mobo I'm choosing would give the same option to OC later, when I'm ready or enough brave to do so, maybe I'll adquire Quad Extreme from QX's Series, who knows?... In the meantime, I'll like to try with a simple option that I know may work without too much tweaking...
[Maybe OFF-TOPIC]
Thank you, once again, ghislaing, Fruity and Zorg... I appreciate all your help and time...
The Q6600 is about the same price and definitely the choice for what you are doing. The DDR3 is a waste. You can OC the Q6600 to 3G in your sleep with the S1283 to cool it.
Thank you for all the time and help you've spent on me...
I have rearranged completely all the original configuration, so now, I'm spending a little less, and gained maybe a little performance by doubling the total memory and going for a QuadCore, yet a lower video card. The new configuration I've chosen is:
And, yes... Do not be amazed by the pricing, I live in Argentina so all the prices have taxes and importation stuff which raises everything a little bit...
What do you think? Is it a good configuration for a 2yr-life-span PC, with OC capabilities, extensible configuration over time? Should I go for it?
PS: I'm forced to apologize If a mod sees this post, maybe I've gone a little bit off-topic since the start of this post, sorry about that.
Zorg, no... I looked out for those here, and apparently there are no local resellers... Brands available are: CoolerMaster, PowerCooler, Thermaltake, Vitsuba, XFX, Satellite, Vantec, Sentey, etc... And, of course, dubious generic ones...
The one that I checked before, for U$S 137 it's the PowerCooler PS-550TR Ver. II that's modular... Yet, more expensive... On the other hand, I could get the PowerCooler PS-550TR Ver. II PLUS the Thermaltake Soprano RS101 case, for U$S 250, as a promotional price on the same place...
