I'm not sure you'd tolerate the loud noise levels from a fan running at 100%. My XFX 5850 (admittedly a completely different card) sounds like a vacuum cleaner at 100%. Additionally, you're almost certainly shortening the life of the fan by a LARGE amount. If this card is meant for long-term usage, seriously consider running the fan at a lower setting or leaving it set to auto.
