hi
i'm having real difficulty in trying to replace my old budget mobo. i've emailed the manufacturers, who passed me on to the uk suppliers, who shrugged or ignored me. Surely component sellers or IT repair folk have some kind of system for finding a replacement mobo working through size, chip, function etc. How else is it done?
i have an ECS K7S5A which is starting to cause problems, capacitors looking bad etc, with some problems in use so i would like to replace it.
I don't need or want to upgrade, just buy a new mobo that will work with what i have, and is new for longevity purposes.
It's an ATX case, winxp sp2, athlon 1.6xp, radeon 9600 pro, 512mb ddr ram, and i would like to keep onboard sound and what i think you call a parallel port for connecting my lexmark z43 printer.
I consider that specs have moved on and i may struggle to match with the basic spec i have, but how can i find a suitable budget mobo from all the types and manufacturers available?
Appreciate any help thanks
