Hi all, hope you can help with this odd problem. Sorry about the long post; more info = more useful, hopefully!
I recently upgraded all the important bits of my poota, including a 128Gb G.Skill FalconII SSD drive and Windows 7 HP. All went well for a couple of weeks. Then the other day when restarting, I got a BSOD error:-
Page fault in nonpaged area
Stop 0x00000050
0xFFF88114DFEFEF
0x0000000000000
0xFFFFF88042EF857
0x0000000000005
[The fourth line varies the three digits between the 4 and last 8 on most occasions]
This error occurs immediately after the "Starting Windows" and swirling logo, does a minidump and restarts.
I ended up installing another copy of windows on a spare HDD and was able to use that (using F8 to choose that drive).
Tried system repair with the Win 7 install disk. All searches for errors, viruses, bad sectors etc all came up clean.
Couldn't find anyone with a similar issue.
Then I just gave it a another shot trying to boot the SSD, and it worked!!!!
Ran without issue all day. Then did a restart to complete some Windows updates, and then got the same BSOD error.
Although this time it would go to the where you could try to repair it. But that didn't help and only gave the same error codes as before.
So I think I'm on to something here. Boot from the old drive, it re-assigns the drive letters around again, restart and boot from the SSD and it's fine again. Seems to be something to do with letter assignments, boot sector, or maybe related to the high Ultra DMA CRC errors I'm getting with the SSD.
Hopefully that's enough clues for someone to be able to come up with a solution that doesn't require booting from the old/secondary OS.
Stop 0x00000050
0xFFF88114DFEFEF
0x0000000000000
0xFFFFF88042EF857
0x0000000000005
