Hi, I'm trying to fix an older PC that all of a sudden won't boot. It is running XP pro SP2. The hard drive is a WD 200 thats seems to spin up ok? meaning it makes noise.
Dispite what I do at start up I can only get to the windows advanced options menu where it asks if I want to start in safe mode, normally, etc.. I can get to bios as well. No matter what I pick it always comes back to this advanced screen. I suspect I have bad boot files on my hard drive? of course this hard drive has important info that hasen't been backed up in a long time! Should I put my bootable XP CD in and do a system replace or fix?
I tried to hook the drive up to another XP PC as a slave. it see's the drive but when you double click on it it says "F:\ is not accessible The file or directory is corrupted and unreadable".
what is the best next step for me in order to save the most data?
Thanks for helping a novice out!
