im sorry if this has been brought up before, but i was just trying to upgrade my PCs RAM. I ordered some new 512K RAM from ebay and when i plugged it in and restarted my computer, i got continuous beeps and nothing comes up on monitor. I tried removing the new ram and plugging in my old ram (which previously worked), but same problem. Ive tried using all of the 3 slots but no use.
I tried using my old ram in a different PC and it works.
I did some research and the beeps i get are 1 beep immediately after start, and then 3 continuous short beeps. I read on another forum that it means "Beeps 1-3-3-3 2A Clear 512K base RAM!"
After some investigation i found out that the RAM i got from ebay is DDR2 RAM while the RAM i previously had was DDR. So maybe by plugging in wrong RAM in wrong DIMM has caused this, and messed my system up.
Have i messed up my RAM slots ??
Does anyone know anything about this or how i can rectify it. Any help would be greately appreciated.
If you managed to put DDR2 where DDR should go,,,, how I do not know as they are keyed,you might have screwed yourself,maybe by reinstalling with your original DDR things might go right...Maybe..Plus you might have to reset your original bios...
