Ok here's the deal. I'm building my daughters a pc after upgrading mine. I'm good with mine it's up and running. I went from an amd 3500 to an amd 6000+ I also went from an ecs geforce 6100pm-m2 to an asus m3a (more of a side grade but wanted to use the ecs for the girls machine). Changed Buffalo ddr2 6400 to corsair 6400. I've also switched from an epower 430 watt to an antec 550 true power trio. Evga 7800gt to a PNY 8800gt. Also switched from a wd 80gig to a wd 320 gig hard drive both 7200 rpms.
Ok problem is I am using all the old components in the new machine but the old motherboard was running the 6000+. I can't get the new machine to post or boot at all with the 3500 in it. I also have a new case for the girls machine. It is a used case and there was no manual. I am assuming that the arrow on the led and power switch is the positive wire. I've tried removing the cmos battery to clear the cmos and I've use the jumper to clear the cmos. I've disconnected everything in the case except the psu hd and ram and I can't get the machine to post even. I know that all the components are good as I was just using all of them so there must be something I'm missing. The hard drive still has on it what it did before. What am I missing?
