So I've had an HTPC for a few years now, and recently my SoundBlaster Audigy 2 ZS began giving up the ghost. It was causing lots of static over the speakers and cutting out when ever anything electrical in the house turned on. So I replaced it with an X-Fi Xtreme Gamer.
No more cutting out when other devices are turned on (like furnace or refrigerator) and no more static.
Here's my new problem:
When I use PowerDVD 8 for BluRay or standard DVD and output the audio over the SPDIF to my receiver the sound will drop out ever so often. Could be 3 times a minitue for a 1/2 second each, or could be once an hour for 1/2 second. Either way it's annoying and I can't figure it out. The sound will also get "out of synch" with the video about 90% through the movie. CPU usage never goes above 65% and is usually in the upper 20's%.
When I play sound through Media Center through the SPDIF to my receiver it has no issues at all, and sounds great.
Driver issue?
Specs:
Windows Vista Home Premium 32 bit
Athlon 64 X2 4200
Thermaltake Big Typhoon (Alu)
FSP Group 400 watt fanless PS
1 GB Corsair Value PC3200
MachSpeed mobo, socket939 (can't remember model #)
160 GB SATA HDD
160 GB IDE HDD
LG BD/HD-DVD combo drive, SATA
NEC DVD burner, IDE
X-Fi Xtreme Gamer, PCI
Asus Radeon 2600 Pro, PCIe
Sapphire Theater Pro 550
ATI HDTV Wonder (using XP drivers)
Rosewill Gigabit NIC, PCIe
Antec Dvine case
Driver issue?
Specs:
Athlon 64 X2 4200
160 GB SATA HDD
160 GB IDE HDD
NEC DVD burner, IDE
Antec Dvine case
