Toshiba external hard drive 2 5 problems
  • Hard Drives
  • Toshiba
  • External Hard Drive
  • Storage
Last response: in Storage
April 1, 2010 7:22:31 AM
Hello,
I have a Toshiba 160 GB Usb mini hard drive. I have tried it on 3 pc's it just does not work. There is a LED on the front of the harddrive which just blinks red and blue. any help?
More about : toshiba external hard drive problems
April 1, 2010 8:09:59 AM
As long as the LED on it is blinking, it shows that the thing is still alive, and maybe just not getting enough power.
I have the exact same Toshiba 160gig mini HDD and it works just fine. Does the data cable on it have 2 usd connectors? If so you should try plugging them both into the machine.
Also sometimes it doesn't work on usb hubs at the front in most pcs. Try plugging it at the back hubs (those at the back of the case).
