- GeForce 8800GTS 512MB SLI (2 of them running at the same time)
Anyways I updated my drivers with the new 180.48 update, after that I went to the nvidia control panel and set the SLI option and it was saying that I have to restart my computer first so I did.
Then I went back there and the SLI option was gone! If I go to "Manage 3D settings" all I see is Global Settings and Program Settings, but nowhere does it say anything about SLI.
And then there is the Set PhysX Configuration which I enabled. But thats all it shows, no SLI option anywhere. Whats strange is that I saw the SLI option before but after that restart its not there anymore. How will I know if I am running SLI and where is the option to enable it?
Message edited by cyborg1 on 11-26-2008 at 06:43:49 AM
Sorry man. I would have replied, but I don't yet have my SLI setup. I am thinking of getting another GPU, especially since the 180 drivers are official, but tagged this thread to find out if anyone answered.
Sorry. I'm hoping for you, just in case this proves to be a problem for me as well. Good luck.
Download GPU-Z and check with it.
Also do a clean install,(Uninstall your driver from control panel,then download Driver Sweeper and go to safe mode and use driver sweeper to clean what its left)
------------------------------Q6600@3.4+ TT V1 Cooler,SAPPHIRE HD 4870X2,ASUS MAXIMUS FORMULA,4GB OCZ DDR2 800,LG W2452V 1920x1200
Reply to Maziar
Hi and thanks for the reply, I think your right that I should do a clean install because I have too many different versions installed. However I want to do this as safely as I can.
Do I remove those drives by going to "Add or Remove Programs" and uninstalling NVIDIA Drivers, NVIDIA ForceWare Network Access Manager, and NVIDIA PhysX v8.10.13?
And what am I suppose to check off in "Driver Sweeper" before deleting?
Message edited by cyborg1 on 11-27-2008 at 01:39:16 AM
Go to Add or remove programs and uninstall Nvidia drivers(all of them),then download driver sweeper and install it.after that reboot and go to safe mode and put a tick in Nvidia display and physX and click "Clean".
Also be sure to check with GPU-Z too.
Reply to Maziar
Always uninstall old display drivers prior to installing new one. At this point, if you haven't done so, you'll need to clean them in safe mode like Maziar said. Be sure not to clean the NVidia chipset drivers (just display drivers), unless you plan on installing new chipset drivers also.
Message edited by pauldh on 11-27-2008 at 03:02:23 PM
