News
Can AMD Survive Another Core 2 Duo?
Opinion - IDF is just around the corner and Intel will provide a flood of new information about its upcoming Nehalem ( Core i7 ) processor as well as its 32 nm and 22 nm successors, new architectures such as Larrabee... Read more
Intel's Core Duo shines in first THG review, dual-core system disappoints
Tom's Hardware has published its first in-depth review of a prototype notebook equipped with Intel's dual-core "Core Duo" processor. While the device demonstrated convincing performance, the system's surprisingly high power consumption leaves questions to be answered in the future. Read more
Intel Announces Centrino 2
San Francisco (CA) - Intel today announced its latest Centrino platform - which oddly named Centrino 2, not just because it really is the fifth generation (and should be called Centrino 5), but also because its brains, the Core 2 Duo processor is just a refresh and may not have justified the new name by itself. Read more
AMD questions current multi-core trend
AMD chief technology officer Phil Hester voiced concerns over the implications of the trend to integrate an increasing number of similar cores into one package. The company indicated that it could part with a strategy of using dozens of cores in one CPU and would turn to developing "Accelerated Processing Units," short APUs instead. <i/Plus: Roadmap update:,/i> Read more
Latest Reviews & Articles
Reader's Voice: An Introduction To Home Automation
Perhaps you've heard about Bill Gates' remote-controlled home and thought to yourself that the technology to automate your own home was decidedly out of reach. Today, Tom's Hardware reader John Knutson walks us through what it took to get his home wired. Read more
Perfect Notebook Storage: Seven 2.5” 500 GB Drives
We compare the latest 500 GB notebook drives from Fujitsu, Hitachi, Samsung, Seagate, Toshiba and WD. Seagate is first manufacturer to reach 500 GB at 7,200 RPM, but which is really the best drive? We loaded up our updated test system to find out. Read more
Mainstream Graphics Card Roundup
You don’t always need the fastest graphics card around. For somewhere between $135 and $235, you can game like crazy in DirectX 10 without a problem at 1920x1200. We test and compare five graphics cards from this mid-range price segment. Read more
USB 3.0 Ups Peripheral Bandwidth
The new USB 3.0 interface is just about ready. It'll accelerate throughput from the 480 Mbit/s of today's USB 2.0 to 5 Gbit/s, which is important for storage and peripheral devices. But USB 3.0 also introduces power saving options. Read on for more. Read more
All the Reviews & Articles
Questions about Power
Hi everyone, I have a few questions.
I've been running on an Ultra 600W power supply for a good 3 years now. I was wondering If I should upgrade to a new one...
Everything works for the most part in XP, but I also dual boot vista. When im In vista, I cannot, for the life of me, get SLi to work. I have two 8800 GT's which work in XP. However when I try to get it working in vista, I just get a black screen with a blinking line. I had been going through this problem for months, but I just decided to leave it alone and use XP. However, I'm getting annoyed now. back then, some Forum goers had told me that my PSU was too weak. I had scoffed at first, but I was wondering if they were right after. I can now afford a new PSU, so i figured that I would ask again. Specs are as follows
Ultra 600W SLI ready psu
Intel Q6600
2 x 8800 GT's
4 GB RAM
2 hard drives
Asus P5N-D
many...many...many fans to keep it cool...
Thanks!
Sponsored Links
I can not see how the PSU would work any different in XP vs. Vista.
I would suspect a driver issue. Are the mobo and vga drivers up to date, and the correct version for the respective OS's?
Reply to geofelt
- 0 +
I agree with geofelt 100%.
Reply to aevm
That's the thing... I have used older Drivers and they... Work... but it's still unstable. I suppose that I could check again.
Reply to bluejay98
I agree also. If it works with one OS and not another, I don't see how it would be hardware related.
Reply to shortstuff_mt
Looks like driver problems to me too. Have you tried any of the BETA drives? Some times they work better than the final drivers (happened to me on XP x64 a few times).
------------------------------ http://farm4.static.flickr.com/3508/3704673463_031d0c96b9_o.png
^Click to find out more
Reply to Shadow703793
Nah, OK i just bought a new PSU for the heck of it anyway. Since the Topic has been switched over to the Nvidia driver issue anyway... I have tried TONS of drivers. Older versions HAVE worked once or twice, but the end result is that the game I was playing was glitched and had graphical corruption. My OS is up to date, so that's not the problem.
To shed further light on it, I select Enable SLI, click Apply, and then Yes, and then the thing freezes (normal) but then it goes to a black screen with a blinking line in the top left... And then it goes back to desktop with everything functioning EXCEPT for the control panel. After being frozen for about 20 seconds, it crashes, and it virtually deletes itself from the computer, with no record of it ever being on there. I've been trying on and off for months, and I'm getting really annoyed. Any ideas?
Reply to bluejay98
- 1 +
An idea:
Abandon SLI.
Sell the 8800GT's, and get a single faster card.
Reply to geofelt
Thanks for the suggestion, but that's not the answer that I was looking for...
Reply to bluejay98
Tom's Hardware > Forum > Homebuilt Systems > General Homebuilt > Questions about Power
There are 976 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
