I built a computer for the first time and it has performed great until two days ago.
I have an ASUS P5K-V board with an Intel Core 2 Duo. On boot up I get the ASUS P5K-V window and then I hear a rapid sound almost like very fast drumming. The computer loads windows XP without problem.
When I open either Outlook Calendar or MS Excel. the noise starts again and a dashed line is rapidly drawn within the excel file systematically replacing existing data with dashed lines. When I olen a time window in calendar the dashed line appears again and I can't enter anything.
Sometimes the dashed line appears in the entry window when I open Google.
I updated the BIOS but the problem continues. ZAny suggestions here as to how to solve the problem?
Are these dashes appearing as if they are being typed in where the cursor is, or are they screen artifacts that could appear anywhere?
It sounds like the "-" key may be stuck down.
Message edited by jtt283 on 10-29-2008 at 08:10:22 PM
------------------------------There is ALWAYS a drone. Exactly where, or how many drones you will encounter may vary, but that there will be at least one will not.
Reply to jtt283
The appear as if typed in, centered in the appropriate window. It is as if I am holding down the dash key, but that would not explain the rapid clicking or drumming sound. Imagine one click or drum beat per dash.
If the key is stuck down, the clicking is the keyboard buffer overflow signal.
Reply to jtt283
Just switched the USB connectors around. I get a two tone sound when I unplug a USB connect and another when I plug the connector in. Every time I insert the keyboard connector I get the sound indicating the computer recognizes the device. As a test I rebooted and went first to a blank word document. The cursor came up and there were no dashes printed. I opened IE7, clicked on the window to establish a cursor and the dashes immediately filled the window.
How can the key be stuck down in Google, but not in windows?
Don't believe so. I unplugged the keyboard and booted up. Strange boot noises disappeared and when I used the mouse to access Google, there were no dashed lines. Problem is definitively the keyboard!
Thanks for tall the insight on this forum. You help is appreciated!!
