Tom's Hardware > Forum > CPU & Components > Other Components > Power on, no boot with different hardware
Forum CPU & Components : Other Components - Power on, no boot with different hardware
Hi everyone,
I really need help on this one. My desktop (p4 3.0ghz, older intel 915pbl board, 2gig of ddr2-667 ram), after a car trip, would no longer boot. It would turn on, with the HDD and DVD drive LEDs solid, send no video signal and just sit there, doing nothing. So I figured hey, might as well upgrade.
So I bought a new mlb (asus p5ql pro), new cpu (intel e5200) and a new psu (450w corsair). Using the same vid card (radeon x1600 pro), same ram (kingston 2x1gb ddr2-667), hard drive (seagate 80gb), dvd drive (some old lite-on) and case, it does the exact same freaking thing. I tried unplugging the hdd and dvd drives and the same thing happens(minus the LED's being on of course).
I know for sure the monitor works, but have not tested the ram or vid card anywhere else. Somehow though, it doesn't seem to be a ram or vid card issue.
Does anyone have any ideas??
Thanks!
Message edited by dperron on 01-23-2009 at 09:51:08 PM
Sponsored Links
How did you determine taht it isn't a video issue? Have you tried a different video card? Did you try with a single memory module just in case one is defective?
Reply to GhislainG
- 0 +
Well, I just tested with another video card and the issue remains. I've tried 4 different sticks of RAM (individually) with no relief. It almost seems like an electrical issue, so I tried a different power outlet, to no avail. I could not be more puzzled!!
Currently, I have the old motherboard sitting on its box with only 1 stick of RAM, the old CPU and its heatsink + fan, and the old video card plugged in. I connected the 20 pin power adapter (the connector on the board is 24 pins, but the one coming out of the psu is only 20 pins, and it used to work) and the extra 4 pin power plug to the board (the vid card does not require extra power). Exact same result. Oh, and if I remove the RAM altogether, it beeps 3 times, like it should.
Next, I will set up all my new gear (mlb, cpu, psu and vid card) on the cardboard box and test. My gut tells me it won't work. Could it be there's some stupid cable or something I'm forgetting to connect??
Help? :)
Reply to dperron
So your old motherboard detects when memory is missing, but it doesn't work when it's installed? That's weird.
What connectors are available from your PSU to the new motherboard? You should have an ATX 20+4 connector and a 4-pin (or 8-pin) ATX CPU connector. Is is what you connected to your new motherboard when using the new PSU?
Reply to GhislainG
- 0 +
Ok, did the same test with the new equipment and the same results.
The new psu has a 24-pin connector and two 4-pin ones (the mlb only requires one). I plugged those in, a stick of RAM, the new cpu and video card, and still no video being displayed. I tried that one without any RAM and while it does not beep, the video card's fan does not turn (it does when RAM is installed, which seems to indicate the mlb recognized when RAM is installed).
This makes absolutely no sense, right?
Message edited by dperron on 01-25-2009 at 12:10:35 AM
Reply to dperron
- 0 +
We have all been there at one time or another and it sucks.
I find it hard to believe that 2 diffrent motherboard/CPU combinations would have the same type of problem. My first thought is what are the common parts being used because one of them is bad. From what I have read it sounds like the memory and video are the only parts used in both systems on a minuim setup.
My other thought is your old system has a bad motherboard/cpu and the memory or video card is not compatible (for some reason) with the new motherboard.
Reply to PCSoul
- 0 +
In the current minimal setup, none of the parts are common, except for the power cord (though I also tried a different one)! The RAM is common I guess, but I have 4 different sticks and have tried them all individually. I'm starting to wonder if say my original video card was bad, by putting it in my new board, maybe it shorted it somehow?
Message edited by dperron on 01-25-2009 at 01:48:09 AM
Reply to dperron
- 0 +
I had the same thing happen when I changed the RAM in my system - but I didn't change boards.
In my case - pulled CMOS battery for 30 seconds and put battery back in. Presto.
In your case, it sounded more like a power supply problem until you said no RAM causes the 3 beeps. I would still try the CMOS thing.
Message edited by duanes on 01-25-2009 at 01:52:43 AM
Reply to duanes
Have you tried a different video card in the new system?
Because it sounds like a graphics card problem to me...
Reply to BobfaceBilly
- 0 +
Thanks for the suggestion. I just tried pulling the battery and the issue remains. :(
Reply to dperron
- 0 +
I just got a new video card today BobfaceBilly and the same thing happens.
Reply to dperron
I guess it's time to bring it to a competent shop that will identify the root cause of your issues.
Reply to GhislainG
- 0 +
Well, for the sake of closure, here's the winning combination: I put in the old psu, reset the cmos, and bam, it was able to boot. I can't put in the new psu though; the same problem happens with it, cmos reset or not. But it now works with the old psu, which is WAY better than how the day started! Thanks everyone for all your input. Guess I'll be returning the psu!
Reply to dperron
Ahh, glad you got it figured out. Odd that the PSU was bad, those corsair 450's are really nice PSU's.
Anyway its always a nice feeling when you get your dead comp back running. :D
Enjoy the new computer
Message edited by BobfaceBilly on 01-25-2009 at 09:01:43 AM
- 0 +
Thanks BobfaceBilly. To be honest, I still don't know what exactly it was that is/was bad. This is the same PSU I had on my old system and it too would not boot, even after I reset the CMOS on the old board. It seems to be some kind of weird combination of defective old board + defective new PSU + CMOS needing to be reset on a brand new board.
Reply to dperron
- 0 +
Oh Heck - I know what happened - you completely forgot to sacrifice a virgin !.... or maybe it was a pigeon..... I forget, but just use virgin pigeons and you should be good.
Reply to duanes
- 0 +
Lol yes, now off to the zoo to find some pigeons, hopefully of the virgin kind!
Reply to dperron
There are 836 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
