Ok so I just ordered and bunch of new parts for my system. It's an HP w/ AMD Athlon 64 X2 3800+ and runnin on Vista Premium 32 bit. I have upgraded it with 3 gigs of Corsair RAM, BFG 650W PSU, and a GTX 260 core216. Basically I am planning this overhaul to relieve the bottlenecking that is goin on with my GTX 260.
On the way I have a Asus P5N-D nForce 750i SLI Socket 775 Motherboard , Intel Core 2 Duo E8400 3Ghz 6MB 1333FSB CPU , ZEROtherm Butterfly CPU Cooler BTF90 , and Thermaltake Tsunami Alum/Clr Side Case. I plan on swapping all this plus the rest of my system (Hard Drive, DVD-RW) to the new case.
This is the first time I have done anything this major to my system, I am fairly confident in my ability to figure things out as I go, but I'd really rather not go in blind, so Im basically lookin for some direction as to what to expect and as to what problems Im likely to face. Will I need to install Vista again? (Im really hoping I dont have to shell out the dough to buy it.) Do I install the drivers for the new Mobo and CPU before putting them in? Will there be any problems switching over the Hard Drive to all the new hardware? Please, any help would be appreciated.
