Haven't built a system in a very long time. I will be using the system for web browsing, word processing and spreadsheets (OpenOffice) and MATLAB. I can't measure exactly how much power the matlab stuff will require so the best I can say is that extra power will be more useful to me than an average non-gamer. OS will be some kind of Linux.
This is my design (prices excluding tax and shipping from newegg)
$50 DVD + HD bought from friend for (360GB Maxtor)
Total cost including tax and shipping is $512.
I figure the E5200 is cheap and powerful enough running linux. I would consider E7200 for $40 more. Mobo is cheap (aimed at corporate users) and since I don't plan to OC it looks like a good deal. Also I like microATX and space is a factor. I believe the RAM is the fastest supported by the mobo. Monitor is a good deal and the case power supply is reported to be reliable on newegg.
Mostly I would appreciate comments on any obvious problems, issues installing Linux on this system, whether it needs a BIOS flash and whether to use the E7200.
well it looks like this metlab program will be the most demanding program you run. i would suggest stepping up to the E7200 just cause it is faster. this metlab program is probably optimized to run on four cores, in which case it would be better to get the intel Q6600. you can probably find out metlabs website.
Thanks for the advice. I was thinking about the Q6600. Do you know if the mobo/ram/psu would be a bottleneck if I was using the Q6600? If it only took a change of processor I'd be willing to spend $100 more for the increased speed, but if I needed to spend $150+ more for a better mobo and maybe power supply I'd just stick to the above (with the E7200).
Matlab is optimized for 4 cores, I didn't realize that before.
Thanks for the advice, the system works. Ended up installing Vista Business because I couldn't figure out how to install the ethernet driver in Linux. Vista runs well, at first the LAN worked intermittently but now it's fine. Internet explorer also hangs but Mozilla is ok. Only other problems were mobo only has one IDE port (and one Floppy drive port!) which might be a problem for some, and case power LED doesn't fit mobo connection.
