Agreed. And good to see from you Dahak heheh long time no post
------------------------------I went drifting, thru the capitols of tin, where men cant walk and cant freely talk, and sons turn their fathers in
Reply to jaydeejohn
depends really... at 1440x900 or below a 9600GT will suffice for anything... and yes even crysis. at 1680x1050, things start to get more interesting, and i would start recommending a 260 for max performance. 1920x1200 i would recommend tow 9800GT's. that could also work for 1680x1050 tho...
okay, but the GTX 260 is way out of budget range. Both of the cards I am listing are half that price. What I would like to know is which of the two cards that I had listed will perform better.
Thanks for the feedback though. It is much appreciated as I am very new to building.
Hey guys, I shifted the post over here (http://www.tomshardware.com/forum/258332-31-help-budget-build#t1871827) as this is part of a larger process. Thanks
