Will this heat sink fit my case?
Forum CPU & Components : Power Supplies, PC Cases & Case Mods - Will this heat sink fit my case?
The heat sink I would like to put in my case is a Noctua NH-U12P SE1366 here is a link.. http://www.newegg.com/Product/Prod [...] 6835608007
The Heigth of this heatsink is 6.23 inches.. I wonder if anyone else out there has use thse two products. Here is my monster and I need to keep her cool.
http://img.photobucket.com/albums/v172/KHIEM/5.jpg
http://img.photobucket.com/albums/v172/KHIEM/13.jpg
This case has a side fan that is pretty large... 230mm Fan and im guestimating this at 1 inch deep.
Thermaltake Armor+MX
GIGABYTE GA-EX58
Intel Core i7 920
GeForce GTX 260
G.SKILL 3GB DDR3 1333 7-7-7-18 Tri-Chan
Seagate 500GB/80GB
CORSAIR 850W
G15 board/G5 mouse
Samsung 2433 x 2, 24" lcd
XPpro-32/Windows7-32 beta
Sponsored Links
Why aren't you running on 64 bit yet??
oh and yea, if i can fit my Xigmatek S1283 in a Centurion 590 then you should be able to put that in there.. but, your going to have the one fan on the heat sink really close to the fan mounted to the back of the case, unless u have both fans suckin in air then it should be fine. pretty high priced heat sink.... did u look into the Xigmatek S1283??
Message edited by fullmetall on 01-26-2009 at 05:47:06 PM
Reply to fullmetall
Im waiting one the ZALMAN CNPS9900 for the LGA 1366 to be released, not long now.
Nice mutt ;)
Reply to merlinbadman
If your pc case is 8 to 8.5 inches wide you'll probably be okay.
I've got the CoolerMaster HAF 932 with a large tower style cpu heatsink and a large 230mm fan on the side panel. There is plenty of room left over but that's because the case is 9 inches wide.
Reply to JohnnyLucky
Thanks for the quick replies. I am still learning about OC'in and keeping my cpu cool. So far I like this the best. There is also liquid cool... but not sure what is nice yet. I do like thick hoses if I was going liquid.. any sugguestions? price limit is no more then 200.
thanks.
Reply to sgtbomber
Tom's Hardware > Forum > CPU & Components > Power Supplies, PC Cases & Case Mods > Will this heat sink fit my case?
There are 1164 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
