Tom's Hardware > Forum > Homebuilt Systems > New System Build > Crossfire Power Supply requirement
Forum Homebuilt Systems : New System Build - Crossfire Power Supply requirement
Just wondering whether the Corsair 620w-HX can handle 2 hd4870 cards efficiently? Or any suggestions on alternative PSU?
And my next question will sound real silly, but can i crossfire HD4870 with HD4850?
Sponsored Links
620 watts for a Crossfire setup with two 4870's is cutting it very thin. I wouldn't suggest anything under 750 watts but then you didn't add in what other power requirements are as in how many drives and fans all that good stuff that would also effect power draw. A Corsair 750 watt unit should be fine. I'm using a Thermaltake 750 with my two 4870's and it works fine, if the Corsair would have been avalible when I purchased my PSU I would have bought one. As for Crossfiring a 4870 with a 4850 it will work but it would be better to keep with same cards either two 4870's or two 4850's.
Reply to stoner133
i heard of reviews about the PSU quality wise, 620HX is better than the 750W ones.. is that true?
Reply to zhuoyan
All Corsair PSU's quality wise are excellent. But when it comes to running two 4870's the primary concern is output. Right now just looking at the web which the cards operate in 2D the current load from my system is 428 watts. Thats two 4870's, sound card (requires power from PSU), 4 hard drives, one optical drive, three 140mm fans and a waterpump. Now start up a game when it kicks in 3D and draws peak loads 620 watts isn't gonna cut it and my 4870's don't draw power for fans there watercooled. Like I said before you have to concider all the other power drawing sources. You can never have too much power but a lack will cause many headaches.
Reply to stoner133
do u know what is missing out from the Corsair 750TX compared to the 620HX? They should be because the 650TX is cheaper than the 620HX
Reply to zhuoyan
yes that is true, It's because the 520 & 620HX psu are made by seasonic i thought and the others are made by a different company
Reply to col-p-todd
I would only go for the HX620 or otherwise i would recommend a Zalman 750W psu. they are even more silent then the corsair psu's
Reply to col-p-todd
my usage on my PC would be:
1)overclocking q6600 to 3GHz
2)2x640Gb Seagate Sata II HDD
3)2xhd4870
4)xigmatek H-1283
5)Corsair 2x2Gb DDR2 800MHz 4-4-4-12
So I'm hoping 620Hx would be able to handle it well, would it not?
Reply to zhuoyan
here is a link that might help:
http://www.legitreviews.com/article/462/1/
i think it would work, but if it were me i,d get a 750W just to be on the safe side.
Reply to col-p-todd
Well ATi doesn't recommend it either, The list the Corsair 650watt unit as only supporting one 4870, they suggest 750watt. I see they also updated the list to supported name brands and by wattage now.
Reply to stoner133
PC Power & Cooling 750
http://www.newegg.com/Product/Prod [...] 6817703009
Less than $90 after 15% off, rebate and free shipping.
Reply to Newf
I used to have a PC power & cooling psu but they are very loud compared to a corsair and a zalman
Reply to col-p-todd
I'm personally a fan for Corsair. Is there something similar in terms of quality and price compared to 620HX and still be able to crossfire 2xhd4870 1gb efficiently? How's 750W "SilverStone" ST75F ?
Reply to zhuoyan
There are 1178 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
