this is my third hard drive failure in 3 months,
i have been keeping up a manual raid, copying many new files over between the hard drives for the last 3 months, usually once a month. now i lost 3 weeks of data, and have decided manually copying files is ineffective, and i need an automatic solution.
i want something that will do this every day at a specific time if i so chose, this way it prevents big downloads of gb's each from copying partially.
i would love for an easy solution, but that probably wont happen. so i want one that i can trust.
im planning on cloning the c drive with seatools, that way if the c drive or the soon to be new f drive fails, i can replace it with little work and have a bootable working solution, and have some amount of data security.
anyone able to suggest something?
