Solved
Scythe S-FLEX SFF80D noise compare to SFF80C
does there is a big difference of noise between the Scythe S-FLEX SFF80D of 32.4 dba and the Scythe S-FLEX SFF80C of 20dba?
http://www.scythe-usa.com/product/acc/062/sflf80_detail.html
3 answers Last reply Best Answer
More about scythe flex sff80d noise compare sff80c
  1. The answer to your question is yes. The SFF80C is quieter.
  2. Best answer
    Yes there is a big difference in the amount of noise produced by the two fans, as JohnnyLucky said, the C model is the least noisy, however if you are after a relatively quiet fan, the B model is what you want.
  3. Best answer selected by julienlarivee.
Heatsinks Overclocking
