MB MSI PM8M-V Pentium 4
hard drive Seagate 160gb SATA
DVD rom SATA PCMart ( Lite-On ) SA22518X
DVD burner IDE Lite-On LH20A1P
I recently purchased a Lite-On DVD rom drive from TigerDirect and
when it arrived noticed that it was an OEM model ( no cables &
no documentation ). Normally I'm fine with this if everything works.
At least it was not costly.
while running speed tests, I noticed that the DVD rom was only
running at 2x but the same disc on the burner would run
at 11x. I've used 2 different utilites to test the speed and both
come up with roughly the same numbers. The burst speed for the
DVD rom is 3MB/s and for the burner is 42MB/s. The only obvious
thing I notice different is the rom test is labeled CLV and the burner
is labeled CAV.
Could part of the problem be that the SATA on the MB is SATA 1
from around 2006?
I've tried using the Lite-On firmware updating utility but it won't
recognize the rom drive. The PCMart US site doesn't show the
drive.
Is there something I can do to speed up the drive or should I just
live with it?
Thanks.
is labeled CAV.
from around 2006?
drive.
live with it?
Thanks.
