Power supply limits and overclocking
Hello this is my first post and my first thread!!
Well my computer specs are:
Pentium 4 2.4 Ghz simple cooling
1 HDD WD IDE 160GB 8MB cache
1,5 Gb Ram
ATI RADEON 9600 PRO 256Mb with improved cooling
1 sound blaster audigy 2 value
1 NIC
1 DVD-RW
1 DVD-R
and some led and simple funs (1 120mm, 3 80mm)
motherboard QDI PlatiniX 2E
and 280 Max power supply, brand: Premier
I have found a Pentium 4 processor, hyper threading at 2.8Gz
My first question is, will I have problems with the power supply?
According to this site http://extreme.outervision.com/PSUEngine , I found that I am to close to limits, but I don't reach them.
Also if I overclock my processor in the future, I am going closer to the limits.
Do you think that my power supply will endure the power needs of my new processor (non overclocked)??
2 answers Last reply
More about power supply limits overclocking
  1. You should be fine I wouldn't worry to much about it.
  2. Your power supply may be a little iffy.
    Try it, and if it works, great.
    If system doesn't work and you think that it's because of power, get one of these:
    Corsair 400CX (30 amp 12 volt rail)
    http://www.newegg.com/Product/Product.aspx?Item=N82E16817139008
Intel Power Supplies Overclocking Product
