First here are the specs on my rig:
Intel Core 2 Extreme X6800 2.93GHz @ 3.2Ghz
ASUS P5N32-SLI Premium/WiFi-AP LGA 775 NVIDIA nForce 590
XFX GeForce 9800 GTX+ 512MB
Patriot Extreme Performance 4GB (2 x 2GB) DDR2 800 (PC2 6400) PDC24G6400LLK
Vista 64bit Ultimate
Now my issue is I recently bought 2 kits of the Patriot memory listed in my specs (so 4x2GB) the listed timings are 4-4-4-12 @2.2v I have manually set these timings in my bios. My mother board supports up to 8gb of ram however when I have all 8gb installed the computer post fine, the bios shows 8gb but when I get to booting up Vista it loads extremely slow at the loading bar screen and after that it goes to a blank screen like its about to load up but it never does. It should be noted that when I first installed the memory I thought two of the modules were bad so I sent in an RMA replacement now that doesn't seem to be the case. I've received my replacement have mixed and matched the modules in various ways and they all work fine but only boot Vista normally when only 4gb is installed. My bios is upgraded, I have also tried running my CPU at stock speed, I tried to reinstall Vista with the 8gb installed but even the installation is extremely slow and hangs on the product key input screen, nothing seems to be working. Any suggestions? I would really like to get all 8gb working instead of settling for 4gb.
