Hello all,
I have a Sunbeam CCF on the way now and looking for advice on fanplacement.
Currently I have:
1 front bottom 65cfm 120mm Yate Loon Intake
1 Rear 65cfm 120mm Yate Loon Exhaust
1 Top aft 42cfm 120mm (came with case) exhaust
I have one extra masscool 52 cfm 120mm fan not installed.
My case is an NZXT Gamma.
Phenom II X2 550BE, 2 cores only, oc'd to 3.3ghz
Once I install the CCF, would I be better served to move the top exhaust from the aft position, directly above the hsf, to the forward position or would this take flow away from the intake of the CCF fan?
Should I use the Masscool on the bottom side position as a secondary intake or just leave the side grill open as makeup air supply?
Currently my temps on idle are 32c CPU, 29-30c Core temp.
After encoding large 1 to 2 gig videos for burning my max temps are 52c CPU, 47c Core.
Any and all suggestions would be greatly appreciated.
Jeff
Currently I have:
Jeff
