$1500 Water cooled build
darkside94
21
Okay. I am looking at building a strictly gaming system that will be running at 1680 x 1050. The highest i will allow my budget to go is 1500. Im still not dead-set on which platform (Intel/AMD) that I want to build off of so I am very open to suggestions on everything. I also want to do some CPU water cooling, but am not sure what case would be good for the Swiftech H2O-220 system I have picked out. Here are my list of parts I have picked out so far:
Case - Undecided
Motherboard - Undecided
CPU - Intel E8500 (heavy OC!)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115036
Graphics Card - 2 Saphire HD4850 Crossfire
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102775
Memory - G.Skill 2 x 2GB 1066 5-5-5-15
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166
Hard Drive - WD Caviar 640GB SE16 WD6400AAKS
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136218
Optical Drive - LG 22X DVD
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
PSU - Antec NeoPower 650 Modular
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371011
Sound Card - Asus Xonar DX 7.1
http://www.newegg.com/Product/Product.aspx?Item=N82E16829132006
I'll be running Vista 64 most likely
Thanks for all your help and let me know if there is something I missed.
ilovebarny
523
Good cases would be: antec 900/ antec 1200/ or the coolermaster 830.
i recomend you get two 4870's instead of the 4850.
intel processors are the way to go, you picked out a fine one.
you may need to get a little bit bigger psu as well. something more like 750-850 watts.
Dasher
77
Hmm for a good case go with any of these 4
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133062
Thermaltake Armor+ MX
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133056
Thermaltake Armor+(a full tower versionw which also includes a removable mobo tray)
Antec 1200 (or the 900)
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129043
and finally of the best cooling cases you can get for the price imo
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160&Tpk=coolmaster%20haf
159.99 WITH 3x 230mm fans THREEEE
as for your RAM save your self about 30 dollars if you want and get some cooler looking RAM =p
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145197
corsair dominator has about the same specs as the gskill
darkside94
21
Thanks for all the help guys, and I'm sorry I didnt reply sooner(stupid comtrash). I like the 900/1200 but I would definitely have to say that I like the cooler master 932 the most due to its great features! I would like to keep the modular theme if possibe because i have a cooler master 850 that i do not particularly like because of all the excess cords. If you have any recommendations on that i would surely appreciate it!
Dasher
77
Yea you went with my suggestion!!! but one thing i dont like about the cooler master 932
(dont read down if you easily change ur mind)
It feels VERY VERY cheap the material
and its kinda hard to see in the case
darkside94
21
Ive read it before but newegg must have mistakenly labeled the PSU as having 4 x 6 pin pci-e because the review only states it has 3
ilovebarny
523
ilovebarny
523
thats a vary good psu. got decent rails, good reviews, i say go for it.
now of course the Xion 800 watt has better rails and is only 10$ more. and it looks cooler with the blue LED lights. and it has free shipping :).
darkside94
21
Thanks guys. You really keep this forum a pleasure to use! But I have decided to not build another computer for a few more years and I am buying a Xbox 360.
Silverion77
2,106
:O :O :O :O
GET THE PS3 SRYSLY
Its so much better and will surely surpass PS3 now that developers are used to the new coding
It has the Cell processor and better hardware in general and a built in BluRay player. Ive used both and though i agree XBox is good (trying to be unbiased) the PS3 is more superior. Plus u get awesome exclusives like MGS4, Resistance and Little Big Planet (which i just started playing 2 days ago and its AMAZING)
@ Barny, the reason those like the Kingwin and Xion are cheaper is because they dont use good parts....I personally would never use them. Amps and watts arent everything.....Build Quality is. The Xigmatek uses CWT OEM which is the same as the Thermaltake (above 750) and the Corsair TX and HX. They save some money by replacing some parts with cheaper ones....does that make them bad. No, but not as good as the respective Corsairs and Thermaltakes
ilovebarny
523
aa ok gotcha. ill have to see if i can find that article that talked about PSU quality next time.
Thanks for the link! 1+v
Silverion77
2,106
Check out jonnyguru.com or Hard OCP for reviews. They give very good reviews of PSUs. Analyzing quality (parts) ripple, regulation the works. Plus u can learn a thing or two.
The good OEMs, the bad etc. and the good parts. CWT generally are good builds (Corsair TX/HX 1000 only and TT above 750). Xigmatek is the same but use lesser quality capacitors vs. the other CWTs. Delta for Antec atm seems to be very good.
The Antec Signature series has the best stuff seen thus far and has the best regulation. Thats y its price tag is so high for a 650/850 watt psu
For Capacitors Nippon Chemicon, Rubycon and such are all good. Oklahoma Wolf discusses it all in his reviews...
