G
Guest
Guest
Hello,
Just built a new new system. Was hoping to play a few games. The system: Asus P5E Motherboard with an Asus EAH4850 TOP Video Card, 450W OCZ power supply, 4GB Crucial Memory, 500 GB Seagate HDD, Lite-On DVD RW.
The system works but did not work with my Apple Cinema Display 22" (which used to work fine with my old ATI 9800 Pro). The display works when the ATI drivers were not installed (VGA mode). With the drivers installed, the display works for the post and windows startup only. After the ATI drivers load the screen would go black and the power button would blink (short blinks, indicating a video problem).
Dusted off an old 17" CRT which worked. Enabled the cinema display as an extended monitor. Changed the display settings to a larger desk size on the cinema display then the display would work for 2D applications. However, whenever I try to test the direct draw or direct 3d settings or play any game the cinema display goes blank and the power button blinks (short blinks, indicating a video problem). In other word 2D ok, games = black screen.
The directX I am using is Aug 2008, and I have tried Catalyst drivers 8.10, 8.9, 8.8.
OK, now to the point. I have 2 weeks left to send stuff back (with a 15% restock, ouch). Should I get a different monitor (like the Acer X223Wbd 22", from NewEgg) or send back the HD4850 GPU and get an Nvidia? Or send back the Motherboard and GPU to get new with an Nvidia bent?
What would you folks do? I would appreciate any replies.
