I purchased a Creative Soundblaster Fatality X-Fi Platinum PCIE sound card. I have gone around and around with all manufacturers in regards to this issue to no avail. So I am hoping someone here has more knowledge than the CSA's who answer trouble calls with no experience what so ever.
I plugged in the card originally into my 2nd PCIE 16 slot, however it would not register; Next I plugged it into my 4th PCIE 16 slot, woohoooo it saw it. However my temps on my cpu went from 13 celcius idle to 26 celcius idle and my core jumped similarly into the 30's. I contacted them all and was advised by MSI they do not support sound cards plugged into the PCIE 16 slots (strange since its not dedicated for graphics and the card says it can be used in 1X, 4X, 8X or 16X) so I ordered this nifty $80 cord to plug into my covered PCIE x1 slot and ran it around the number 1 graphics card and heatsink (great setup MSI :-(, block all ports if you add a heatsink) and I still get the issue, not only that but before I added the card my benchmarks were over 16k in 3dbenchmark and after wards they increased, another woohooo. I uninstalled the software and hardware and checked again, bummer my benchmarks dropped to barely 15k, even after starting over from scratch and resetting mb by removing the battery I couldnt get the performance I had back, but the temps went back down to normal. So here I am with this dilemma, first why is this hardware causing such a significant increase in my cpu temps, almost doubling it for a friggen sound card and second why did it negatively affect my system in regards to performance. I love the sound quality but the temps are really pushing my coolit, and once they reach a certain point they can actually make your cpu temps higher instead of lower (according to coolit techs, it has to cool itself if the temps get to high and so reverses the cooling) Does anyone here have any idea what is going on, is this normal and just not talked about ANYWHERE, I have performed hours of research prior to posting this, actually days and it all seems to be for naught. I hope someone knows something or even a fix (I would love that).
