So heres the situation, I have an ASUS maximus II formula board, e8500 processor (running stock at the time) with an Arctic Freezer Pro fan and heatsink, an XFX 9800 GTX black edition card.
I want to monitor the CPU temp accurately and have the CPU fan adjust according to various temperatures.
For the 9800 I want to adjust the fan speed or edit the fan speed profile to act in the same manner a CPU would, the card gets hotter the fan goes faster etc.
The whole problem is the inaccuracy of all the programs Ive tried to use.
For example at Idle(temps in Celsius):
ASUS AI Suite reports CPU temp at 21 (no way in hell its right)
SpeedFan reports CPU temp at 46
RealTemp reports CPU temp at 36 (strange its always exactly 10 lower than SpeedFan)
Because my MOBOs reported temps, my fan will try to adjust the fan speed according to AI Suites temp through the use of their program Asus Fan Xpert, and the fan is just way off and no way is it doing its job right. Ive been force to compensate but its just not cutting it.
In nvidia's performance tab on the nvidia control panel it wont let me adjust fan speeds, it always gives me an error saying the settings are invalid when I try to apply.
Ive tried to use RivaTuner but it doesnt work on Vista 64 bit Home.
What are my choices for a resolution? I believe Realtemp to be the most accurate temp for my CPUbut my fan doesnt adjust to that temperature! And my poor Video Card is just sizzling at over 60 Celsius with no way of change! Please help!
