Tom's Hardware > Forum > Graphic & Displays > ATI > Trouble OCing HD4850- Please help!!
Forum Graphic & Displays : ATI - Trouble OCing HD4850- Please help!!
So, I recently picked up an HD 4850.... It seems the average OC for this card is anywhere from 690/1050-725/1150 on stock cooling. I haven't been able to get even the smallest stable OC, even though I haven't seen temps reach even 60 Celsius, even under load.. I'm basically limited to 650/1050, though I still sometimes get the VPU recover @ these clocks... The only true stable clocks seem to be 625/993 (default)
I'm 99% sure there is some other problem with my setup, other than the card. I've flashed the BIOS voltages up to 1.158(I set all voltages for 2d/3d to this amount), which is the max soft-increase for this card. The only thing I can think that might be the problem is a software problem, or a PSU problem.
I've also used drivercleaner, reinstalled 8.11 Catalyst drivers after the flash, have my fan turned up manually to 100% at all times...
Below are my system specs.
Motherboard: Gigabyte GA-P35-DS3L
CPU: Intel E2220 Dual core OC'd @ 3.1
RAM: 2 x 2GB DDR2 800
GPU: Visiontek HD 4850 (currently stock clocks but this is the problem)
HD: 300GB basic HD.
PSU- 450W, not sure of the manufacturer/details (I can get them if this may be an issue)
also, 4-5 case fans and a few LED case lights
Looking for any advice on how to up these clocks... Can't figure out what the problem is, I know this card has a lot of potential.
Sponsored Links
What is the card doing after you try and OC?
BSoD? Display going blank? Driver not responding? Artifacting?
Reply to SizroSpunkmire
I just get the horrid Black screen for a second, followed by a VPU recovery.. If I disable the VPU recovery, i get the blue screen of death.
Reply to M3thod
Could be a power supply issue but from what I've heard...the 4850 doesn't overclock well at all......your really not going to gain much overclocking it anyway.....that cpu you have will still bottleneck it.....just leave it alone....some systems react the way yours does when you overclock everything.....it is what is is.....
------------------------------ Q6600...4870oc
XFX 680i LT Sli...VISTA 64
4g Corsair XMS
Antec P180/550 psu
Reply to jackieboy
The PSU is most likely the limiting factory, your probably teetering on the edge with the PSU then once you OC kablooehy it all goes to hell.
------------------------------ Q9650@ 4.05ghz
GTX285 black edition
2x2gb G.kill 1200mhz
780i SLI FTW
Reply to x_2fast4u_x
So, I checked on my PSU.. please let me know if this is enough... I read somewhere that 450 is more than enough, if it's decent... not sure if this one is.
Antec Smart-Power 450w (2 12v @ 15a and 17a)
http://www.antec.com/specs/SP450_spe.html
I managed to OC to 640/1100 from 625/993 and have gotten stable results.. I was hoping to get the Core higher, but I can't get 3dmark06 to complete with 650/1100 even. I can get 660/993, but it doesn't seem like the results are as good as 640/1100.
Message edited by M3thod on 12-02-2008 at 05:57:10 PM
Reply to M3thod
There are 1261 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
