ok, this is my brothers computer that he build about a two years ago
SPECS:
Asus P5N32-E SLI PLUS
CPU INTEL|C2D E6600 2.4G 775
2GB (2x1024) D/C Kit PN - OCZ2G8002GK 5-5-5-15 1.8v
2GB Dual Channel Kit P/N - OCZ2P8002GK 4-5-4-15 2.1v
XIGMATEK HDT-S1283 120mm Rifle CPU Cooler
PSU ANTEC|TP3-650 RT
On the stock cooler it was over 65 on idle, now it's 55 or more after i installed xigmatek. When i play a game it's over 70C, i check temps using core temp.
These temps are even higher in bios, almost 70C when idle.
The new cooler is installed properly, and we tried to reinstall the old one few times to make sure it was sitting right so it is not the cooler. I flashed the bios with the newest bios from asus too.
Any ideas why so high on overall and especially using this new huge cooler? Nothing is overclocked, bios is loaded to default, only the timings on ram are set so they match.
Please, help.
thx
SPECS:
Please, help.
thx
