I have installed 2x Sparkle 9800gt 512mb in SLI and I keep getting the following message under device manager on my second card. " This device cannot find enough free resources that it can use(Code 12).
I previously had 2x Sparkle 6600gt in SLI and the system worked fine.
I am using the SLI bridge that came with the 6600gt's as i did not recieve a new bridge with the 9800's.
I also noted that there is a small plug next to the SLi slot that I have no cable for and Im not sure if I should plug this in or not?
Can anyone assist me????
I have installed the latest drivers and Physx software but still no result.
the old sli connector SHOULD be k, but i wouldnt be surprised if a new one provided more bandwidth..
the plug next to the sli connector is a S/PDIF something-a-rather cable connector thingy, that allows you to transfer lossless audio to something from something.
in other words, completely unnecessary.
I would say the second one is either not receiving enough bandwidth or power, or the mobo is faulty...
