Right mouse click
Hello,
When I try and right click a file instead of opening the "right click menu" it try's to start installing a program (Scan Soft)and FINALLY after I cancel enough times the right click menu appears..
What is killing me ?
I also have most of the "Security" download sites (MS, McAfee, etc) blocked even if Host's has no problem
1 answer Last reply
More about right mouse click
  1. Scan Soft is a scanner software, have you installed it recently ?
    If not it is a virus, you can run McAfee Avert Stinger (standalone), but suggested to run malware scanner like MBAM or AVG10.
    Make sure no such application is loading on startup, Start-Run type MSCONFIG, check startup and services, do not change services unless specified app. is there.
    If you have ccleaner, lookup what it shows in startup under tools.
Security Mice Windows XP
