Hello,
Im completely confused by this problem....
A few weeks back I was using my computer as normal, went out for a bit and came back to a blank screen.
The system fans were still running and other components such as the HDD & CD-Rom drive still had power,
But nothing would happen on the screen, Completely black.
So I restarted the PC, and nothing.... It doesnt even run in BIOS or any visual Screen.
When you press the power button, nothing happens...
Ive tried disconecting all the devices and try & ive tried a new PSU and still nothing
However.... If I disconect the 4 Pin Power connector to the CPU and press the power button..
The fans start up .... If i then connect the power to the CPU, It turns off
I think its a problem with the CPU as it seems to trip the power...
Or is it the motherboard, Im not sure
Can anybody help ?
Can anybody help ?
