Sign-in / Sign-up
SATA2 Seagate speed dropped to 4MB/s
  • Hard Drives
  • Storage
Last response: in Storage
April 12, 2010 4:56:08 PM
Something happened to my less than a year old HDD. It was running fine until now.
My other drives have speeds from 57 to 70 MB/s - benchmarking in HDTune. The slow drive really kills the loading times of various games (from a few seconds to a few minutes, and from a minute to about 5 minutes).
I tried rebooting, didn't help. I tried to shutdown PC, disconnect drives power and data cables, and plug them again in - still didn't work.
This happened to my PATA drive once - but it just switched to PIO mode, nothing serious. I know that this can't happen to SATA drive, but it might switched to SATA I, right? But still the speeds wouldn't be as low as they are.
More about : sata2 seagate speed dropped 4mb
a c 127 G Storage
April 12, 2010 6:35:21 PM
Next time please mention what operating system you are using.
This sounds like a PIO issue; please use HDTune to identify the PIO issue. Run the standard benchmark. If it shows a horizontal line of no more than 16.6MB/s and has very high CPU utilization, then you are likely running in PIO mode.
Usually, this is remedied by going to the device manager and deleting/uninstalling the primary/secondary IDE controller. Or in your case the SATA controller.
Please note that this issue may be caused by cabling errors; if the above trick doesn't work post the drive's SMART info here. If the number of "UDMA error count" is higher than zero, you have cabling issues.
April 12, 2010 6:35:48 PM
Since I cannot edit my message, I have to bump this:
The problem was actually in IDE controller set to PIO mode :)  Reinstalled it and the speeds jumped to 70-80 MB/s ;)
