New System Question/Help
ok...Never done this before, but here goes!
I am looking to build a new system strickly for Internet surfing only (and possibly to run a very simple Excel spreadsheet). It would be used for web browsing, Internet banking and viewing videos, webcasts only. What would you suggest as far as the parts to purchase and what king of cost am I looking at? Any help/advise would be appreciated!!
Rob
4 answers Last reply
More about system question help
  1. Unless you're just interested in building a system, then a prebuilt one would be a cheaper choice, especially with operating system, warranty and support included in a pre built. Here's a refurbished prebuilt for $260
    http://www.recoupit.com/Shop/Control/Product/fp/vpid/5937676/vpcsid/0/SFV/31197
    New Acer for $384 with full warranty
    http://www.newegg.com/Product/Product.aspx?Item=N82E16883103159
    As for building it yourself. Here's a budget list of parts
    Operating system - Vista home premium 64 bit $100
    http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488
    Case/ power supply combination- $60 Coolermaster w 350w psu
    http://www.newegg.com/Product/Product.aspx?Item=N82E16811119118
    Motherboard with integrated graphics - G31 Foxconn $42
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813186145
    CPU - E5200 $83
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819116072
    RAM - 2x1 GB DDR2 800 1.8v OCZ $17 after rebate
    http://www.newegg.com/Product/Product.aspx?Item=N82E16820227124
    Hard Drive - 320GB SATA Western Digital $60
    http://www.newegg.com/Product/Product.aspx?Item=N82E16822136074
    DVD/CD burner - LG SATA - $24
    http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152
    About $400
    You could shave a bit off this by going AMD, but not much. You could also go a little higher and get a system that has a better path for future upgrades.
  2. I would change MB and CPU
    alot better graphics, HDMI, E-Sata, firewire, HD Audio
    GIGABYTE GA-MA78GM-S2H AM2+/AM2 AMD 780G HDMI Micro ATX AMD Motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813128090
    AMD Athlon 64 X2 5000+ Brisbane 2.6GHz 2 x 512KB L2 Cache Socket AM2 65W Dual-Core Processor
    http://www.newegg.com/Product/Product.aspx?Item=N82E16819103211
    Cost add $14.00
  3. Yep good stuff there.
    Really, for that kind of thing you can pay $500.00 for a new budget laptop. Not only will you be able to do as you describe but you can take it to the coffee shop and when you go on the road ;)
    And a laptop will save you all sorts of money on power.
    Now, if you want the experience of building your own, then DM and knotnut have some good builds for you.
New Build Internet Systems Product
