Hi There
I am thinking about buying a new gaming computer:
- Price mid low range - roughly 1000GBP (might be more)
- gaming purposes mainly
Idea is to be expandable in future - probably Another 4870x2.
Here is what i have got generally on my mind:
>Antec Nine Hundred 900 - Gaming Case with 200mm Top Fan - No PSU
>Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB) - Retail
>DFI LANPARTY LT X38-T2R X38 Socket 775 8 Channel Audio ATX
>Powercolor ATI Radeon HD 4870 X2 2048MB GDDR5 TV-Out/Dual
>Wd 640GB Hard Drive SATA300 7200rpm 32MB Cache Caviar Black - OEM
>Thermaltake ToughPower 750W Modular PSU 14cm ATX12V6x
>OCZ 4GB (2x2GB) DDR2 800Mhz/PC2-6400 Memory GOLD DUAL
>HANNS-G 22IN LCD WIDE HI221D 5MS 1680X1050 SPKR DVI HDCP
>Zalman CNPS 9700 LED Socket 754, 940, 775, 939 & AM2 CPU cooler
What Do You think about it? What would You hypothetically could change?
Small overbudgeting is not a massive problem.
Couple further queries:
<Is 1066 ram much better than 800 ?
>is my mobo good with chosen cpu and ram?
<is PSu enough for future xcross ?
Kindly Thanks in Advance for all Your response.
Regards
Regards
