I just recently went to do a standard reformat, something I typically do every few months. Went through the original Vista x64 Install and the install took several hours and froze during the completing installation step. I then tried to reinstall again and began receiving errors that the hard drive could not be formatted. I have 3 HD drives and tried them all. I began think maybe my hard drives went bad and ran seatools to check its health. Sea tools came back fine. Tried to install windows 7 beta thinking maybe it was a bad disk and the same error occurred. Then tried go back to XP 64 and got a partition incompatible error. Ive tested my ram, came back fine tested other disk drives same problems occurred. I recently got a new mobo and cpu and beginning to wonder if the mobo is bad. I haven't had any problems with it up till now. Is there something Im missing or test I can do to test the mobo?
Specs:
Gigabyte GA-MA770-UD3
Phenom II x4 920
4gb Patriot ddr2 1066
Asus 4870
750w PSU
HDD: 150gb WD raptor, 250gb Seagate, 300gb Maxtor
Thanks in advance for any help.
Specs:
Phenom II x4 920
Asus 4870
750w PSU
