Tom's Hardware > Forum > Homebuilt Systems > New System Build > problems, problems, problems...
hey, okay i just built my system, updated BIOS, CPU, GRAPHICS CARD, drivers. However, when i run counter strike: source i get high fps for like 5 secs and then drop to 4 fps or less! =/
i've done the 3dmark05 test and i get a score of 2800's! :'( very very BAD.
i basically get 0 fps when running cpu test
something is holding back my system,
here are my system specs:
CPU: amd 3.0ghz athlon 64x2 6000+ temp is @ 40-50 with zalman cooling 92mm and some other 5 fans in the case.
GPU: gtx 260, my card's bus interface is at pci-e x16 @ x16, and the bandwidth is 114.9 gb/s
PSU: 650TX CORSAIR
HDD: 250gb sata/7200 rpm barracuda
MB: http://www.newegg.com/Product/Prod [...] 6813131281
RAM: ddr2 1066 4ghz G.skillz, dram frequency at 375MHz/ 5.5.5.15 timings
MONITOR: 22" HDMI ASUS/1680x1050pixels/59hz
alrite i was wondering if the mobo has something to do with making the system not run like it suppose to, and not get the score im wishing to get, maybe because is a cheap motherboard?? or the ram is affecting the system?? or i should just take it to a shop to take a look around??
any1 could HELP??!!! THX A LOT!! is really frustruating.
Sponsored Links
Check the BIOS and make sure the PCIE bus is set to 100MHz. Make sure you have up to date drivers for your GPU. And open up the case and make sure you have plugged in the PCIE power connector to your GPU...
Start with that and lets see what happens.
Reply to Slomo4shO
"temp is @ 40-50 with zalman cooling 92mm and some other 5 fans in the case. "
Is that the temp at idle? Did you apply thermal paste when you mounted the CPU cooler, and did you clean the old material off first?
This sounds like CPU throttling to me.
Reply to Proximon
Even without thermal paste being applied, the CPU should not be overheating to the point of where throttling would become rampant.
Message edited by Slomo4shO on 11-10-2008 at 12:07:57 PM
Reply to Slomo4shO
LMAO, what are you counting on convection?
Reply to bobbknight
40-50 is pretty high if you are checking when the system is idle....how high do your temps get under load? I agree you should check your heatsink installation.
Reply to jitpublisher
- 0 +
the PCIE bus is set to 100mhz, i have up to date drivers and both PCIE power connectors are connected to my GPU
Reply to Diiego
- 0 +
yes i applied artic silver 5 before cleaning the old thermal paste it had, the cpu cooler is mounted the right way
Reply to Diiego
There are 958 identified and unidentified users. To see the list of identified users, Click here.
Sponsored links
